Hi everyone,
I am wanting to upgrade my PC. Although when I say upgrade I mean start from scratch and buy a whole system.
I am looking to spend a MAX of £1000.
I'm not the best with specs and what is compatible or whatever hence the topic.
Here is what the PC is going to be used for:
Gaming - I mainly play Arma 3, but I also play other like Dying Light, Battlefield and more.
Video editing and rendering - I got a camcorder for my 21st to start my fitness channel on Youtube so would be good to have decent rendering speeds for 1080p etc..
General PC use - Of course the usual Youtube, Facebook.
I mainly use my PC for playing online games and when I get my new build I will be using it for video editing and rendering as stated above.
I have done a little looking around online, my friend said I should get the new GTX 960/970/980 with a Intel i7 Haswell processor. Thoughts on that?
I would also like SSD for fast boot ups and games and hard drive for all my other files.
I don't really know where to start. My biggest struggle is choosing which motherboard to go for.
I am from United Kingdom and mainly buy from Aria or Overclockers UK.
Any help or suggestions is greatly appreciated.
https://linustechtips.com/topic/315313-new-pc-build-help/
PCPartPicker part list: http://uk.pcpartpicker.com/p/XW46xr
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  (£260.34 @ Aria PC)
CPU Cooler: Corsair H110 94.0 CFM Liquid CPU Cooler  (£91.31 @ Aria PC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  (£88.76 @ Scan.co.uk)
Memory: Corsair XMS3 16GB (2 x 8GB) DDR3-1600 Memory  (£99.95 @ Amazon UK)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  (£42.76 @ CCL Computers)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.99 @ Aria PC)
Video Card: EVGA GeForce GTX 980 4GB ACX 2.0 Video Card  (£449.98 @ Scan.co.uk)
Case: Corsair 760T White ATX Full Tower Case  (£145.00 @ Aria PC)
Power Supply: Silverstone Strider Essential 700W 80+ Bronze Certified ATX Power Supply  (£48.90 @ Scan.co.uk)
Optical Drive: LG UH12NS30 Blu-Ray Reader, DVD/CD Writer  (£39.59 @ Aria PC)
Total: £1304.58
Generated by PCPartPicker 2015-02-22 12:43 GMT+0000
I suggest this.
Where I hang out: The Garage - Car Enthusiast Club
My cars: 2006 Mazda RX-8 (MT) | 2014 Mazda 6 (AT) | 2009 Honda Jazz (AT)
PC Specs
Indonesia
CPU: i5-4690 | Motherboard: MSI B85-G43 | Memory: Corsair Vengeance 2x4GB | Power Supply: Corsair CX500 | Video Card: MSI GTX 970
Storage: Kingston V300 120GB & WD Blue 1TB | Network Card: ASUS PCE-AC56 | Peripherals: Microsoft Wired 600 & Logitech G29 + Shifter
Australia
CPU: Ryzen 3 2200G | Motherboard: MSI - B450 Tomahawk | Memory: Mushkin - 8GB (1 x 8GB) | Storage: Mushkin 250GB & Western Digital - Caviar Blue 1TB
Video Card: GIGABYTE - RX 580 8GB | Case: Corsair - 100R ATX Mid Tower | Power Supply: Avolv 550W 80+ Gold
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4285488
@DannyG
Do you need a monitor as well ? or is this just for the tower ?
Well I am getting a monitor soon, suggestions on that would be good too!
I have also changed my max price to £1000, this is taking into account other things I want to buy which are not tech related. (I can go slightly higher than £1000 if needed)
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4285699
Just under budget, assuming you don't need a copy of Windows  :)
Also if you need a DVD drive then you would have to get an external one.
The PSU is big enough for SLI GTX 970.
Motherboard: Gigabyte GA-Z97X-Gaming 3 ATX LGA1150 Motherboard  (£89.98 @ Dabs)
Memory: Kingston Savage 16GB (2 x 8GB) DDR3-2400 Memory  (£95.99 @ Amazon UK)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£79.48 @ Amazon UK)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  (£275.94 @ Aria PC)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£59.94 @ Scan.co.uk)
Power Supply: XFX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£69.99 @ Amazon UK)
Total: £999.14
Generated by PCPartPicker 2015-02-22 14:03 GMT+0000
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4285850
I would look at a G-Sync or a 144Hz screen if you want it more for gaming.
An IPS/PLS type screen would give you better colour reproduction but it wouldn't be as fast as the above two types.
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4285868
Ok thanks. I would need a copy of Windows too, but I wont include that in the price of the build.
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4286171
Total: £999.14
This build.... so good..... Maybe swap out the PSU for the EVGA 650w one, as it's a bit cheaper and will still be enough for the SLI. But aside for that, it's extremely solid.
Anyway, here are some monitor suggestions. I believe you should go for a 1440p display, 144hz 1080p monitors aren't worth it imo. You can get Dell U2515H for extremely high pixel density, or you could go with the traditional 27" size and get the BenQ GW2765HT. Both are IPS, so that's a nice bonus.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4286362
The XFX is a better PSU. I have the same one in my own pc :)
 I am not a fan of the EVGA NEX units.
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4286429
That XFX is clearly worse. Has no full modularity B).
Gimme a full review proving it's superiority, and I might change my mind.
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4286549
Being Semi Modular doesn't make it worse.
The NEX is a group regulated FSP based on the Aurum.
The XFX is a Seasonic based on the M12II.
Here is a review of the 650W version - http://www.hardwaresecrets.com/article/XFX-PRO-650-W-XXX-Edition-Power-Supply-Review/1604/1
https://linustechtips.com/topic/315313-new-pc-build-help/#findComment-4286812
