Hey guys,
Can any of you recommend a build that can max out games like planetside 2, battfield 3,4 and hardline, the batman arkam series, titanfall, cg:go, gmod, the arma series, and skyrim. I also wanna be set for any new games coming out in the future like The Division. My budget is around $600-$700. But in the build I need to include a monitor and keyboard and mice. Thanks in advanced guys!
https://linustechtips.com/topic/315152-help-building-a-computer/
Keep in mind that Arma has pretty bad optimization. Most games mostly uses the GPU but arma requires you to have a powerful CPU. Also do you want to get a high end gaming mouse and mechanical keyboard? The mouse could cost up to $100 and a good mechanical keyboard could cost up to $180. Also a good 1008p monitor would cost you $150.
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4283600
Tried my best:
CPU: AMD FX-6300 3.5GHz 6-Core Processor  ($94.89 @ OutletPC)
Motherboard: ASRock 980DE3/U3S3 ATX AM3+ Motherboard  ($53.98 @ Newegg)
Storage: PNY XLR8 120GB 2.5" Solid State Drive  ($65.00 @ Amazon)
Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($192.98 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case  ($49.99 @ Amazon)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  ($29.99 @ NCIX US)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Total: $712.09
Generated by PCPartPicker 2015-02-22 01:06 EST-0500
You could remove the SSD and get a better CPU if you wanted, but this should do pretty well. Could use the ol' thumbstick method for the OS to save ~$100
i5 4690K @ 4.5Ghz | OC'd XFX R9 290 | 8GB DDR3-1600 | 1TB HDD, 250GB SSD | Gigabyte Z97X-UD5H | 650W Rosewill PSU | Rosewill Thor White V2 Case | Windows 8.1 | 1440p 144Hz Freesync 27" |1080p 60Hz 24"
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4283603
I would suggest building an AMD based APU system. A nice powerful 7850k processor paired with some high speed AMD Radeon branded memory (at least 2133mhz). You would be able to run most games at high settings in the 45-60fps range and the more demanding titles at medium settings 1080p. I build a similar system for a friend and with peripherals came out to $5-600 USD. With this type of setup you can sort of "test the water" and see how the games feel. If later on you feel like you want more then slap a beast graphics card in there and you can run even the most intensive titles maxed at 1080p. just make sure you have a good power supply  to make the upgrade later on easier. Good luck with whatever you decide on :)
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4283655
an i5 would be ok wouldnt it? and I really dont care about the mouse and keyboard, should spend more than 30 bucks on a bundle. im aiming for high settings at at 60fps
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4283672
would it be possible for you to put this a pcpartpicker list? this sounds like a really good idea
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4283733
You're not going to be able to hit 60fps 1080p in those games without a dedicated GPU:
http://www.pugetsystems.com/labs/articles/AMD-A10-7850K-Performance-Review-529/
This is at very low settings, ~720p, and struggling to hit 60fps.
The 280X is definitely capable of 1080p 60fps at high settings.
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4283757
http://pcpartpicker.com/p/2Jh423
This should leave you with plenty of upgrade-ability later on. You may want to consider shopping around for a similar motherboard to better fit your specific needs though.
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4288263
This is honestly really mediocre for $700; as I said before, you're not going to be able to get even 1/2 way to 1080p 60fps with integrated graphics no matter how fast your RAM is in modern games. http://www.guru3d.com/articles_pages/amd_a10_7850k_apu_review,10.htmlEven if you upgrade your computer later by putting in a dedicated GPU, that's still a mediocre CPU in it.
Whereas a 280X will be able to achieve 1080p 60fps in almost every game you throw at it http://www.techspot.com/review/841-radeon-r9-280x-roundup/page9.html
I changed the build to remove the SSD and put an i5 in there if you want a more powerful processor.
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($169.61 @ OutletPC)
Motherboard: ASRock H81 Pro BTC ATX LGA1150 Motherboard  ($51.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($34.99 @ SuperBiiz)
Total: $709.72
Generated by PCPartPicker 2015-02-23 03:59 EST-0500
This will absolutely destroy any APU system.
https://linustechtips.com/topic/315152-help-building-a-computer/#findComment-4292468
