I want to create a pc for gaming and streaming so i want to know if this is good.
Case: NZXT H440 – Designed by Razer  ($150.00 @ Razer)
CPU:Intel Core i7-4790K 4.0GHz ($320)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.99 @ SuperBiiz)
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard  ($137.99 @ SuperBiiz)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($328.99 @ Directron)
Memory: 16GB 2133MHz DDR3 (2 x 8GB) DDR3-2133 Memory  ($150.00 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($150.00 @ MicroCenter)
Storage:Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive  ($75)
Power Supply: EVGA SuperNOVA 850W  ($125.99 @ Newegg US)
OS: Windows 7 (15.00$ @ reddit)
also is the mother board be alright with all of it.
budget:1500$ no peripherals
https://linustechtips.com/topic/314809-build-plan/
Poorly matched components. No color scheme. Give me 15 minutes to whip up something better.
This is going to be similar in performance and significantly prettier
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($319.73 @ OutletPC)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler  ($59.98 @ OutletPC)
Motherboard: ASRock Z97 EXTREME6 ATX LGA1150 Motherboard  ($149.99 @ Micro Center)
Storage: OCZ ARC 100 240GB 2.5" Solid State Drive  ($89.99 @ Amazon)
Video Card: XFX Radeon R9 290X 4GB Double Dissipation Video Card  ($309.99 @ Newegg)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($95.99 @ NCIX US)
Case Fan: Corsair SP120 57.2 CFM 120mm  Fan  ($12.99 @ Amazon)
Total: $1268.63
Generated by PCPartPicker 2015-02-21 13:40 EST-0500
Aesthetics of rigs matter
42
If you're interested, participate in LTT Build Offs
https://linustechtips.com/topic/314809-build-plan/#findComment-4279428
1 - Replace the SSD with a 850 PRO or a mx 200.
2 - A 290x is a good option also if you dont have anything against me recommending it.
3- Overpriced memory , get this http://pcpartpicker.com/part/corsair-memory-cmz16gx3m2a1600c10
https://linustechtips.com/topic/314809-build-plan/#findComment-4279433
I'll be waiting for you. Once you do your build, I'll try to update it with my personal touches  B)
I'm totally not being lazy, it's just that I'm on a notebook with crappy wifi and 0 of my bookmarks, instead of my usual home
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/314809-build-plan/#findComment-4279497
If you're going to get a evo, get the 850 Evo...
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($279.99 @ Micro Center)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($118.48 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($118.98 @ OutletPC)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card (2-Way CrossFire)  ($279.99 @ Amazon)
Total: $1566.09
Generated by PCPartPicker 2015-02-21 13:57 EST-0500
(I'm $66.09 over budget but this is probably a good price/performance.)
a Moo Floof connoisseur and curator.
:x@handymanshandle x @pinksnowbirdie || Jake x Brendan :x
Youtube Audio Normalization
https://linustechtips.com/topic/314809-build-plan/#findComment-4279546
Crossfire ready.
CPU Cooler: Phanteks PH-TC14PE_BK 78.1 CFM CPU Cooler  ($64.99 @ Newegg)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($99.00 @ Amazon)
Video Card: Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card  ($291.98 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($109.99 @ Amazon)
Total: $1174.40
Generated by PCPartPicker 2015-02-21 14:07 EST-0500
https://linustechtips.com/topic/314809-build-plan/#findComment-4279700
