Has linus done a comprehensive video on cable management?
I've currently got a thermaltake case with as far as I can tell, No space behind the motherboard for cable management and I don't really know how to sort it out properly.
for example my cpu power cable (8 pin is it?) barely fits over the top of my gtx 670 and I can't think of a better way of doing it.
Could someone give me some pointers? or even suggest a nice clean looking case with good cable management options if thats the best way.
Thanks in advance!
https://linustechtips.com/topic/314708-cable-management/
Route your CPU power cable behind the end of the GPU then to the left around the CPU socket and up to the connector.
Just take some time and think about what would make the most sense. :D And use zip ties.
Time and zip ties. :D
who cares...
https://linustechtips.com/topic/314708-cable-management/#findComment-4277929
