Hello everybody!
I have a really weird problem with my computer:
I recently bought a GTX 970 (evga), installed it in my case, and at boot up, the phase with the bios logo showing up is EXTREMELY long, like 2-3mins. After that, everything seems to work fine. So what i wanted to do is change some bios settings, thinking that a simple tweak would do the job. But, surprise! When i try accessing the bios menu; black screen.
I re-installed my old gpu (gigabyte gtx 650) and changed some settings and one setting seemed to resolve the problem: "ENABLE ONBOARD GAPHICS". Now the problem is that, with this option activated, ive got plenty of other problems (with drivers, etc).
Now my question is: how can i solve the original problem? (Slow bios startup/bios blackscreen)
PS: -with the old gpu ive got NO problems at all.
-my windows 7 is running on an ssd drive that i installed after buying the computer, so it wasnt originally on that drive.
My setup:
Motherboard : Gigabyte h77-ds3h
Cpu: intel core i7
Drives: - 1TO western digital Hard drive
- 256go samsung ssd
Power Supply: FSP HEXA 500-550W
Hoping that someone can help!
https://linustechtips.com/topic/314587-new-graphics-card-booting-problems/
All the cables are connected and the card can't be defective, because, as i said, after the slow boot everything works just fine. I can play almost all games on ultra, with nearly 60fps. The problem seems to be some BIOS configuration stuff.
To be more clear, when i enabled "Internal Graphics" and re-installed the new card (GTX 970) the PC boots up fast, i CAN see the BIOS, and all the games do work fine. BUT, when i update drivers, the screen becomes black and i have to reboot. But the point is that this problem is caused by the fact that i enabled the internal graphics. My question is how to resolve the original problem. (Slow boot/Can't see BIOS)
Btw, still thanks for the quick answer :)
