Hey guys,
So i have just finished building my pc, and when i turn it on, there is no video output to my monitor.
I have the video card connected to the monitor using a HDMI cable.
I have tried several times, but the monitor just would not get a signal.
Specs:
AMD FX8350
MSI 970 Gaming Mobo
Sapphire R9 280X TOXIC
8GB DDR3 RAM
750 Watt Cooler Master
Can anyone please help me?
Reply on this thread or add me on skype: jos.millenaar
Thanks!
Dan
https://linustechtips.com/topic/314554-boot-problem/
Possibly, by any chance are you using something like a TV for a display. I once had a similar situation where a new video card I installed wouldn't wake up my 47" Sony TV and I vaguely remember having to resort to connecting an actual monitor to the other port (and possibly making it the primary one) before the TV would be given/sent a signal, at which point it would remain on even after redisconnecting the old temporary monitor, until that is, that I turned off computer again, so I had to resort to leaving the old monitor hooked up, not used and sitting on the floor.
https://linustechtips.com/topic/314554-boot-problem/#findComment-4276835
So you had to have the old monitor connected for the new monitor to work?
https://linustechtips.com/topic/314554-boot-problem/#findComment-4276913
Try using just one ram stick in each slot and see what happens .... then try two. Because things appear to boot and then stop, it could well be a RAM issue.
i5 4670k @4.2ghz / MSI Z87 G45 / EVGA GTX 960 SSC / Samsung  840 EVo SSD / WD Green 1tb HDD / Corsair H75 / Corsair Obsidian 750D / Corsair CS750M
https://linustechtips.com/topic/314554-boot-problem/#findComment-4277623
Do you hear any beeping when you power on the machine? Read the manual on what ramslot you should be using and try with 1 stick of ram first, if it posts enable xmp.
CPU I7 - 4720HQ RAM 2 x 8GB • GPU Nvidia GTX 850M Storage 250GB 850 EVO - 1TB Seagate Hybrid
Keyboard CM Storm QuickFire Rapid-I (MX brown) & Pok3r (MX clear) • Mouse Logitech G502 • Sound Audio-Technica ATH-M50X • OS Windows 10 Pro - Linux Arch
Storage Asustor AS7004T
https://linustechtips.com/topic/314554-boot-problem/#findComment-4279435
