Okay so i run my pc and in the midst of downloading a game or something or even at idle i get the "WHEA_UNCORRECTABLE_ERROR" . I heard this is due to voltages? Mostly. Now im not sure but it happens the most when i download something so i am going to buy a new hdd tomorrow anyways . But i have a i7 4790k with a Ga z97z SLI mobo and my vcore is at 1.037 ? And my cpu clock ratio at 4.0 but for some reason on software it says im clocked at 4400mhz which is 4.4 right? I need help and i dont know what the standard volts are and i keep getting BSoD
https://linustechtips.com/topic/313660-help-wih-bios/
what board do you have?............ or.......( with the machine unplugged )... you could remove the battery for a minute and put it back ( the way it came out ) or you could read the booklet that came with your motherboard or you could go to the board manufacturers site and read the pdf.
https://linustechtips.com/topic/313660-help-wih-bios/#findComment-4264390
