This is my build below:
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor  (£205.80 @ Amazon UK)
Case: Corsair spec 01
Motherboard: MSI H97 Guard-Pro ATX LGA1150 Motherboard  (£51.03 @ Amazon UK)
Memory: Kingston Fury White Series 8GB (2 x 4GB) DDR3-1866 Memory  (£56.09 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£45.00 @ Amazon UK)
Video Card: Gigabyte Radeon R9 280 3GB WINDFORCE Video Card  (£146.99 @ Amazon UK)
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply  (£38.68 @ Amazon UK)
I want to buy a better motherboard but not spend more is there any better options for my build and also if i use my 4 pin fan connector on my mobo how do i change the fan speed? under bios? because under bios it only shows for cpu :L
https://linustechtips.com/topic/313567-need-help-choosing-alternative-mobo/
Do you already have these parts? Also there's probably few options in the BIOS because that board was built for BitCoin mining.
i5-4690k @ 4.2GHz | Asus Radeon R9 290 DirectCU II | Hyper 212 EVO | ASRock Z97 Extreme3 | Corsair Vengeance 8GB 1866MHz, Corsair XMS 4GB | 850 EVO 250GB, random 1TB drive | Corsair 200R | EVGA SuperNOVA 750W | Rosewill RK-9000BR | Logitech G700s | Logitech G930 | ViewSonic VG2427wm, Dell S2209W, Dell S2009W
Dell Inspiron 3147
Latitude E5420, Samsung 840 EVO 250gb, 12gb RAM, 1600x900 display
Pentium G3258 @ 3.2GHz | WD Red 2TB x3 in RAID-Z, Crucial MX100 128GB(cache drive) | Fractal Design Node 304 | Gigabyte GA-H97N-WIFI | Crucial Ballistix Sport 8GB | EVGA 500B
HTC One M8 64GB, Droid Razr M
and what is bittcoin mining?
Its basically letting people borrow your processing capabilities especially with GPU's and sometimes your CPU's. It usually consumes a lot of power but you let your computer work for you so that you can earn crypto-currency or online money that has its own value. Basically it just consumes power in exchange for online money that can only be used in certain places. Also i would recommend this mobo:
MSI Z97-G55 SLI ATX LGA1150 Motherboard
Its a little more expensive however i would say that its worth it and it has a great life length as well as an easy bios to go through.
CPUi7 4790k (4.0 Ghz)| MotherboardMSI Z97 Gaming-5 ATX LGA1150| RAM: 16 Gb Corsair Vengeance Pro(DDR3-1600, Red 4x4Gb)GPUEVGA GTX 980 4GB Superclocked ACX 2.0| CaseFractal Design Define R5 (Black with Window)| StorageWestern Digital Caviar Blue 1TB and Samsung 850 EVO 250 GB SSD| PSUCorsair HX750i 80+ Platinum| Display(s) Asus VG248QE 144Hz 24.0" CoolingCorsair H100i GTX| Keyboard: Corsair K95 RGB| MouseRazer Deathadder Chroma|
However if that is a little too expensive for you i would recommend a
MSI Z97 PC MATE ATX LGA1150 Motherboard
But to be honest a mobo wont really change a whole lot of performance in your rig so IMO i would just say that you should choose a mobo that you like the color scheme on, has the features you need (idk maybe you wanna sli some day or something) and can handle your current equipment
But it wont make a huge difference if you choose something like a really cheap Asrock mobo vs an Asus Maximus 7 or something except for possibly the chipset, the color, the features, and obviously those mobo's are designed to handle a lot more hard knocking gear like i7 cpu's, 980 gpu's in sli, and 32 GB of ram and stuff. So really just choose a mobo you like
sorry i couldnt explain, my class period ended and then the next period was pe so i didnt use my laptop
Dell Inspiron 3147
Haha oh, i had today off because of "snow" even though theres like 1 iceicle outside
