**CPU** | [intel Core i5-4690K 3.5GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54690k) | $219.89 @ OutletPC
**CPU Cooler** | [Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler](http://pcpartpicker.com/part/cooler-master-cpu-cooler-rls24m24pkr1) | $79.99 @ Newegg
**Motherboard** | [Gigabyte GA-Z97X-UD3H-BK ATX LGA1150 Motherboard](http://pcpartpicker.com/part/gigabyte-motherboard-gaz97xud3hbk) | $126.99 @ SuperBiiz
**Memory** | [Corsair Vengeance 16GB (2 x 8GB) DDR3-1600 Memory](http://pcpartpicker.com/part/corsair-memory-cmz16gx3m2a1600c10) | $124.99 @ Amazon
**Storage** | [intel 730 Series 240GB 2.5" Solid State Drive](http://pcpartpicker.com/part/intel-internal-hard-drive-ssdsc2bp240g4r5) | $131.98 @ Newegg
**Video Card** | [Asus GeForce GTX 970 4GB STRIX Video Card](http://pcpartpicker.com/part/asus-video-card-strixgtx970dc2oc4gd5) (2-Way SLI) | $328.99 @ Directron
**Case** | [Fractal Design Define R5 w/Window (Black) ATX Mid Tower Case](http://pcpartpicker.com/part/fractal-design-case-fdcadefr5bkw) | $117.99 @ SuperBiiz
**Power Supply** | [EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply](http://pcpartpicker.com/part/evga-power-supply-220g20750xr) | $99.99 @ Micro Center
**Case Fan** | [Corsair Air Series SP120 High Performance Edition (2-Pack) 62.7 CFM 120mm  Fans](http://pcpartpicker.com/part/corsair-case-fan-co9050008ww) | $27.98 @ OutletPC
 | *Prices include shipping, taxes, rebates, and discounts* |
 | Total (before mail-in rebates) | $1657.78
 | Mail-in rebates | -$70.00
 | **Total** | **$1587.78**
Any thoughts on how this looks?
In a few weeks I will be starting my first build, not some cheap overpriced pre built thing.
EDIT: I have 1 500gb hard drive and 2 250gb hard drives (all run at 7200rpm) that I will temporarily be using untill I feel like getting a terrabyte drive
I also already have the motherboard and ssd as I got them both for under $200 during black Friday last year.
GPU - 2x GTX 970 g1 gaming (sli) CPU - I5 4690k 4.6Ghz Cooler - Kraken x61 PSU - Corsair ax760 RAM - 32gb Corsair vengeance pro 2400mhz Storage - 730 Series SSD 240gb Case - Phantek enthoo pro
https://linustechtips.com/topic/313487-first-build-look-good/
swap out the Corsair 750W for the EVGA 750W G2.
i'd get the Phanteks Enthoo Pro
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261421
EVGA G2 is cheaper and the best recommendation.
What are you going to use this system for?
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261439
Repost?
I posted in build logs and meant post here, oh well
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261462
They both look like fine power supplies, but the EVGA is $20 cheaper so hey why nhot, I considered the Enthoo pro but Im not going to use any of the optical bays and I like the r5 look more.
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261521
@King Oriax this looks great, however you might consider getting the R5 with a window to show your horses. i recommened getting a other psu maybe from seasonic or evga.
the Supernova G2 from evga is freakin awesome: http://pcpartpicker.com/part/evga-power-supply-120g10750xr
or the Seasonic: http://pcpartpicker.com/part/seasonic-power-supply-s12g750
Case: Corsair Obsidian 450D with 2x SP120 / 1x AF120 Mainboard: Z97 Msi Gaming 5 CPU: i7 4790K @4.0 Ghz CPU-Cooler: Noctua U14S RAM: 16 GB DDR3 Corsair Vengance 1600 Mhz GPU: Sapphire Vapor-X R9 290X HDD: WD Green 2 TB SSD: Samsung Evo 250 GB PSU: Corsair RM 750W Monitor: BenQ XL 2411z 144hz 1080p
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261530
Gaming, photoshop, a little bit of stuff in maya, some adobe after effects, nothing insane
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261549
Then definitely go for 4790K and two 970 or two 290x. Or even a 980.
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261570
The 850W G2 is currently $5 cheaper than the 750W model after rebate   :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438018&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261778
Can't decide between r5 and the Enthoo, the r5 has better cooling for the gpus, but the front intake inst as good as the enthoo.
https://linustechtips.com/topic/313487-first-build-look-good/#findComment-4261874
