high cpu temps
Go to solution Solved by Nikolithebear,
Should i just get an aftermarket cooler? If yes then which one is the one that has the best price/performance ratio?
Yes go get an aftermarket, CM 212 is the go to replacement.
Hi guys,
i have an i7-4790k on an asrock z97 extreme4 board with the stock cooler ( :P)
About half an hour ago my computer crashed while watching a youtube video, i had several chrome tabs opened but nothing else.
I built the computer about a month ago, i didn't worry about it too much but i decided to run a stress test.
I downloaded prime95 and they said to run it for about 6-12 hours but after 2 minutes i had it on my cpu went to 99° celsius...
What should i do? Should i just let it destroy my cpu?
Something else i noticed was that it was only using 4 of 8 GB of ram but since it's a stress test shouldn't it use it to the fullest?
Thanks in advance,
bye!
EDIT 02/24/2015:
All right the hyper 212 evo came in today, i ran aida64 for about 5 hours and the cpu never went higher than 67 °C, i am impressed, it's an excellent cooler!
https://linustechtips.com/topic/312290-high-cpu-temps/
first dont use prime 95 download aida64
@Splashzed
Gaming rig) i5-4690k@3,5ghz,4,1ghz turbo , gigabyte z97x-gaming 3, hyperx fury red 2x4gb(1600mhz), msi GTX 970 gaming 4, corsair cs650m PSU, corsair carbide spec-03 case, be quiet pure rock Cpu cooler, kingston v300 120gb ssd, samsung evo 830 120gb ssd, segate baracuda 1,5tb hdd, Laptop 1) HP pavilion power, i7 7700hq, 16gb ddr4, 256gb nvme ssd, 1tb hdd, nvdia gtx 1050 Laptop 2(linux mint)Dell Xps 15(2011), i3-2130m, nvidia gt525m, 4gb 1333mhz ram, 500gb hdd Laptop3(mint and windows)Dell inspiron 15z(2013), i5-3337u, hd 4000 graphics, 6gb 1600mhz ddr3, 500gb hdd, 32gb ssd(RST) First PC(still using for some windows XP programs)Amd athlon xp 1500+@1,96ghz, 2gb 300mhz ram, PNY geforce 6200, 80gb maxtor hdd, asus(tek) a7n8x-deluxe , 450W psu, spire case
https://linustechtips.com/topic/312290-high-cpu-temps/#findComment-4244770
Hi guys,
Thanks in advance,
bye!
99 oC is too much. You're in the danger zone. Unexpected shutdown can be explained by CPU temps climbing too high. I never used stock coolers but I guess their lack of performance don't account for temps that high. Have you checked if the cooler is seated properly ? Have you used aftermarket thermal paste ? If so, how did you proceed in applying it ?
https://linustechtips.com/topic/312290-high-cpu-temps/#findComment-4244918
@Splashzed
I used aida64 and it got to 98° celsius, i ran the cpu, fpu, cache and system memory test together. It says that it detected overheating...what should i do?
It didn't shutdown, it just crashed i mean it wouldn't do anything, i had to restart it..i didn't check if it's seated properly but when i do normal tasks it just gets to max 32° celsius so i think it's seated properly...i didn't use aftermarket thermal paste...
https://linustechtips.com/topic/312290-high-cpu-temps/#findComment-4244983
