Slow download speed
Go to solution Solved by Hans Christian | Teri,
Because you're using a wireless USB adapter. What make and model is it? Most of them are absolute rubbish.
whats the adapter?
what are your internet speeds
run a speedtest at http://www.speedtest.net/
https://linustechtips.com/topic/312216-slow-download-speed/#findComment-4243572
Try using a laptop right next to the router and if u get less than 80% of the spees of your advertised speed then theres a serious problem and i would return it ;)
My tplink for £15 works flawlessly :)
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
https://linustechtips.com/topic/312216-slow-download-speed/#findComment-4244796
