I am doing a simple loop for my cpu for a school project for physics. I need to be able to change pump speed and radiators easily because that is what I am testing. Here is my parts list:
Block: EK-Supremacy MX CPU
Radiators: ALPHACOOL NEXXXOS ST30 (one 240mm and one 120mm)
Pump/Res: EK-XRES 140 DDC 3.2 PWM
Fittings: Need help with this one but they need to be compression so I can reuse the tubing after I switch out radiators
Tubing:  PrimoFlex Advanced LRT
Fans: I have some Gentle Typhoons that I am going to use
My cpu is an i5 3570k and my case is a Corsair 350D
Thanks
https://linustechtips.com/topic/312183-help-with-first-loop/
looks like a good loop however is a bit overkill for a core i5
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/312183-help-with-first-loop/#findComment-4243212
well you will need some QDCs( quick disconnects) atleast 6 QDC fittings other than that just use any compressions that fit the look you are going for.
for the QDCs you need 1 before the rad and 1 after
and then 2 extra ends per rad
How much easier would the QDC make switching radiators as I will only be doing 3 combos, the 120, the 240 and the 120 +240
https://linustechtips.com/topic/312183-help-with-first-loop/#findComment-4244177
