Help with Frameworks; engineering maths
Hello
I would like some help with a question that i have in Mechanical Science,
I cant seem to do this questions as it confuses me that the supports are on the side and how the support forces dont at up to the forces being put on 15kn
If anyone would like to give this a go it would be much appreciated :)
mech.pdf
https://linustechtips.com/topic/312139-help-with-frameworks-engineering-maths/
Very basic stuff, did you get it? give me 5min.
Case : Corsiar Air 540 CPU : Intel i5 8600k GPU : Asus Nvidia 970 DirectCUII RAM : 16gb DDR4 MB : ASUS Prime z370-p PSU : OCZ Modxtreme 700w SSD : Samsung 840 EVO 250gb
Hello
You still need help? Also remember to follow your topics, you won't know we have replied unless you do so.
Well, as im not a believer of giving the answer on a golden platter for maths related work, I've drawn this to give you a helping hand.
post-56584-0-68017900-1424224452_thumb.j
 (63.44 and 26.56 are angles, my bad, forgot to draw on angle sign before taking picure)
Some hints
I would recommend working out the forces as a magnitude and the angle it acts in
Work out the forces of BC first
arrows pointing inwards suggests the structure is under compression and outwards is torsion.
Also remember moments WILL come into play here!
I would first take the moment force about A to give you the wall's reaction force at B.
After that you only have the X and Y reaction forces at A which are unknown, so those can be found by summing the forces in the X and Y directions. Just find the sqrt(Rx^2 + Ry^2) for the magnitude then Tan(theta) = Ry/Ra.
At this point you should have all of the external forces so you can just look at each of the corners FBD's to give you the normal forces in each of the members.
