Posted January 27, 2013 I plan i on getting a new case when i redo my PC but cant think of what case to get i have two in mind the corsair c70 or the corsair 650D Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 Either one is fine. Choose the one that looks better for you :P Asrock 890GX Extreme 3 - AMD Phenom II X4 955 @3.50GHz - Arctic Cooling Freezer XTREME Rev.2 - 4GB Kingston HyperX - AMD Radeon HD7850 - Kingston V300 240GB - Samsung Spinpoint F3 1TB - Chieftec APS-750 - Cooler Master HAF912 PLUS osu! profile Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 Both are excellent cases. If you want more airflow get the C70. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 The 650d and 800d are designed for watercooling. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 I have the 650D and it was the best investment out of all the hardware I bought. The build quality is outstanding (typical Corsair quality), it is very easy to build a system in, great cable management, and good airflow. The C70 is very similar to the 650D on the inside, the feature set is basically identical, and also has the same great quality. This is a personal choice obviously, but I definitely recommend the 650D, because of everything I listed above, but mainly because of the sleek, subtle looks. The C70 is a bit more flashy, but again, all personal preference. i5 3570k - MSI Z77 GD65 - 16GB Corsair Vengeance - Galaxy GTX 780 - Corsair AX650 - Custom CPU Loop - Corsair 650D - OCZ Agility 4 128GB - WD Black 640GB Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 Author I have the 650D and it was the best investment out of all the hardware I bought. The build quality is outstanding (typical Corsair quality), it is very easy to build a system in, great cable management, and good airflow.The C70 is very similar to the 650D on the inside, the feature set is basically identical, and also has the same great quality. This is a personal choice obviously, but I definitely recommend the 650D, because of everything I listed above, but mainly because of the sleek, subtle looks. The C70 is a bit more flashy, but again, all personal preference. thanks i want to know if you can you put two 120 fans on the front or would i need to mod the case i dont like the 200 fan and i would like to have a h100i on the top Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 Author The 650d and 800d are designed for watercooling. im not sure the 650 as much as the 800d that thing is huge i do plan to use a h100i Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 27, 2013 Author Both are excellent cases. If you want more airflow get the C70.if i want to use a h100i would the c70 better then? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 In my opinion the 650D is a lot more attractive with its sleek features and it looks a lot more high-end, maybe I'm just bias against the military look of the c70? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 Both are excellent cases. If you want more airflow get the C70.Both will work great. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 Author In my opinion the 650D is a lot more attractive with its sleek features and it looks a lot more high-end, maybe I'm just bias against the military look of the c70? ya i and also the window on the c70 does not look good with the fan mounts Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 Author I think im going to get the 650D when the time comes thanks fpr your help Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 I prefer the look of the 650d but choose the case which you think looks better. Good Morning... Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 As an alternative, think about the Fractal Arc series. Really stealth look, great airflow and value. I love my arctic white Fractal Define R4, but that is a different look than your going for. The smaller midsize, Arc Mini (R2 version) was just redone to allow for great watercooling options; as a slightly smaller options for you. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 28, 2013 Author As an alternative, think about the Fractal Arc series. Really stealth look, great airflow and value. I love my arctic white Fractal Define R4, but that is a different look than your going for. The smaller midsize, Arc Mini (R2 version) was just redone to allow for great watercooling options; as a slightly smaller options for you.i will take a look at them also good to have a open mind Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
