Hello guys, this is my pc that I am planning to build. Please tell me where should I change or is this build good for now? My budget is $1200. Here is my build, thanks :)
http://pcpartpicker.com/p/q7BRyc
Looks great, but get a 2x4GB ram kit instead of a 1x8GB, other than that it looks all good
https://linustechtips.com/topic/311934-my-first-pc/#findComment-4239754
Thanks alot for helping me out :D
1x8b and 2x4gb doesnt really matter, get whichever that is cheapest
I would suggest going EVGA for psu.
That case is way too old, get something like a s340
I personally would go for r9 290 (better $ per FPS)
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/311934-my-first-pc/#findComment-4239843
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.89 @ OutletPC)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard  ($139.99 @ Micro Center)
Memory: Team Elite Plus 8GB (1 x 8GB) DDR3-1600 Memory  ($56.99 @ Newegg)
Storage: Samsung 840 EVO 250GB 2.5" Solid State Drive  ($131.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($354.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($67.99 @ SuperBiiz)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($34.99 @ NCIX US)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.75 @ OutletPC)
Total: $1190.22
Generated by PCPartPicker 2015-02-17 02:15 EST-0500
This is a more refined version (removed CD drive)
OR
Video Card: XFX Radeon R9 290 4GB Double Dissipation Video Card  ($249.99 @ NCIX US)
Total: $1085.22
Generated by PCPartPicker 2015-02-17 02:17 EST-0500
Same performance for a lowered cost.
https://linustechtips.com/topic/311934-my-first-pc/#findComment-4239862
 @bleachichigo I would stay with the GTX 970 instead of the AMD GPU, the R9's heat up pretty fast. Using 2x4 GB RAM or 1X8 GB RAM doesn't really matter, go with what is cheapest.
other than that everything is great in the build.
good luck with your build.
https://linustechtips.com/topic/311934-my-first-pc/#findComment-4241711
Thank you for your blessing :)
https://linustechtips.com/topic/311934-my-first-pc/#findComment-4283556
