i perfer the dot in the middle
I always use the Rice-Sized-Dot-In-The-Middle method.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Last time I changed thermal paste I did a % sign, diagonal line with two small dots at each empty corners, works really well. Hard to find a test that compares all methods of applying, but as far as I can tell, the "X" method is the best, the dot is also really good. Remember that the cpu die under the heat spreader is quite a bit smaller, and that most of the performance will come from covering that die.
Doesnt matter really, all work fine. Noctua themself in their cooler manuals reccomended the dot in the centre
My rig. Case & psu: evga hadron air. Cpu: Intel i5 4690k. Gpu: MSI gtx970 4gd5 OC. Mobo: Gigabyte GA-z97n gaming 3. Ram: 2x4gb Crucial Balistics Tactical @ 1866mhz. Cooler: Noctua NH-U9B se2. Ssd: Crucial mx100 512gb.
