Help with 1TB HDD selection.
Go to solution Solved by Captain_WD,
Hello,
My HDD just failed and I am in the market for a new one. I don't really have a budget, but that is not to say I want to spend $150-200 on a new one. I need at least 1TB, but I have been out of the HDD game for a while and I don't know what to look for. I mean, except for the obvious Western Digital or Seagate.
Anyhow, can any of you help my pick a new one out? It will be used for storage...mostly games.
Thanks!
Hey johnnyTheMac,
If you plan on using the drive for gaming and you don't have a SSD, I would suggest checking out WD Black (as the guys suggested). It is a performance drive with an integrated dual-core processor that managed multitasking very well and works great as a gaming drive. Here's a link: http://products.wdc.com/support/kb.ashx?id=4J5mDs
If you don't need a higher performance drive and a regular one would do the job, I would suggest checking out WD Blue. It can handle gaming perfectly fine and is a bit more quiet than WD Black, but is limited to 1TB in size. Here's a link: http://products.wdc.com/support/kb.ashx?id=oYdQlK
Games rely on storage only for their loading times and FPS and graphics aren't affected in any way. Pretty much any drive would handle most gaming, unless a certain game is more storage-demanding and needs to load bigger texture files while in-game. :)
Captain_WD.
Hello,
Thanks!
CPU: Intel i7 3770K | Motherboard: Gigabyte GA-Z77X-UDH4 | RAM: 8 GB Blue Ares | GPU: Gigabyte Windforce 780 GHz Edition | Case: Corsair C70 Vengeance Arctic White | Storage: 250 GB SSD Corsair Neutron - 128 GB SSD Kingston - 1 TB WD Black | PSU: Corsair 850 watt | Display: 3 x Dell S2340M 23-Inch IPS
https://linustechtips.com/topic/311434-help-with-1tb-hdd-selection/
http://www.newegg.com/Product/Product.aspx?Item=9SIA5AD1P08389&cm_re=hitachi_2tb-_-1Z4-0005-00041-_-Product
These are the ones I use Because there cheap and I havent had one die on me yet but even if it did I could buy 2 for the price of a WD Black
if you are scared of the life time of the drive you can go for a WD Black of respective space size wanted, but if you don't you can't go wrong with a wd blue.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
Western Digital Black is good.
Case: Corsair 4000D Airflow | PSU: Corsair RM750X V2 | MOBO: ASUS ROG Strix B450-F GAMING | CPU: AMD Ryzen 7 5800X3D | Cooling: CM Masterliquid ML240L RGB | RAM: Ballistix 32GB DDR4 3600MHz CL16 RGB | Storage: Samsung 970 EVO M.2 + Kingston NV2 NVMe | GPU: XFX Radeon RX 6950 XT Speedster MERC 319
Hello,
Thanks!
Hey johnnyTheMac,
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
Id get a WD green or red, its not the fastest but its pretty quiet. Loud HDD's make me cringe
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
