Nvidia Gtx 660 overclocking problems
Solved by mvitkun,
you may depending on the carddo i also need to increase the voltage?
it depends on the game,a less intensive game will probably show an increase,in a more intensive game a good overclock might raise your fps by 2-5fps.What I am wondering is if a 100 MHz increase is too small to make a noticeable difference in a game
how much worse?was it within a margin of error?When i first tested my card at 1080 MHz, it benchmarked slightly worse than at stock
the more intensive the game the less of a difference there will be between different tiers of cards,so an overclock will be very unlikely to show.I am using gpuZ, msi afterburner, msi kombuster, and fraps to benchmark my graphics card in far cry 3.
