2.1 set up... i think. Help please
ZombieFish19
Hello LTT community. I'm very novice when it comes to audio.
Right now i have these speakers
http://www.amazon.com/Micca-MB42-Bookshelf-Speakers-Tweeter/dp/B009IUIV4A/ref=sr_1_1?ie=UTF8&qid=1424027915&sr=8-1&keywords=micca+mb42
and  this amp
http://www.amazon.com/s/ref=nb_sb_ss_i_1_5?url=search-alias%3Daps&field-keywords=lepai%20lp-2020a%2B&sprefix=lepai%2Caps%2C200
im asking for help because I want to add a Subwoofer to my setup but then I would need a new amp, and im having lots of trouble finding anything 2.1. I not even sure if im looking for the right thing. Any help would be much appricieted. thanks for your time.
You dont need a new amp. You just need a sub with Speaker input/output. Look at this one http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130. Just using that one as an example cause it has pictures of the amp. But thats what youre looking for.
PC Audio Setup = Beyerdynamic DT 770 pro 80 ohm and Sennheiser pc37x (also for xbox) hooked up to Schiit Fulla 3
so if I got something like that, how would I hook up everything? Would I go amp to sub to speaker?
yes.
