Hi Guys,
I am wondering if anyone could recommend a X99 chipset build within the budget of £1300 for my Fiancee and I. We would use the system for Tasks such as Programming, Web Design, Virtual Machines and playing the latest games.
Things I Don't Need:
Monitor
Mouse/Keyboard
O/S
I look forward to seeing some of the builds.
https://linustechtips.com/topic/310940-x99-build-recommendation/
Do you really need X99, like REALLY
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4225994
Well for VMs you could justify it if you run a lot but honestly a 4790k would be enough for that
@StevenGibson1994
Unless you go balls to the wall on your VM's you don't need all the extra cores that X99 brings
RIG: I7-4790k @ 4.5GHz | MSI Z97S SLI Plus | 12GB Geil Dragon RAM 1333MHz | Gigabyte G1 Gaming GTX 970 (1550MHz core/7800MHz memory) @ +18mV(Maxed out at 1650/7800 so far) | Corsair RM750 | Samsung 840 EVO 120GB, 1TB Seagate Barracuda | Fractal Design Arc Midi R2 (Closed) | Sound Blaster Z        Getting: Noctua NH-D15 | Possible 250GB Samsung 850 Evo        Need a console killer that actually shits on every console? Here you go (No MIR/Promo)
This is why you should not get an FX CPU for ANY scenario other than rendering on a budget http://linustechtips.com/main/topic/286142-fx-8350-r9-290-psu-requirements/?p=3892901 http://linustechtips.com/main/topic/266481-an-issue-with-people-bashing-the-fx-cpus/?p=3620861
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4225999
I came up with this build here in the X99 chipset. What do you guys think?
PCPartPicker part list: http://uk.pcpartpicker.com/p/MkczjX
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (£303.98 @ YoYoTech)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  (£84.99 @ Amazon UK)
Motherboard: Gigabyte GA-X99M-GAMING 5 Micro ATX LGA2011-3 Motherboard  (£170.36 @ Scan.co.uk)
Memory: Crucial 8GB (1 x 8GB) DDR4-2133 Memory  (£73.34 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£39.95 @ CCL Computers)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  (£274.99 @ Novatech)
Case: Corsair Air 240 MicroATX Mid Tower Case  (£72.43 @ Amazon UK)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£63.84 @ Amazon UK)
Total: £1083.88
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4226403
X99 Can make use of quad channel Ram. So swapped your choice over to 4 x 4GB instead.
The EVGA G2 is a better psu.
The H100i has a few issues (Mounting and also with Win 8.1) The Coolermaster Nepton 240M is a good alternative.
I put a 256GB SSD in. If you don't need one then just take it out.
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor  (£303.54 @ Aria PC)
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler  (£79.99 @ Amazon UK)
Motherboard: Gigabyte GA-X99M-GAMING 5 Micro ATX LGA2011-3 Motherboard  (£169.94 @ Aria PC)
Memory: GeIL 16GB (4 x 4GB) DDR4-2400 Memory  (£189.59 @ Overclockers.co.uk)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  (£79.48 @ Amazon UK)
Case: Corsair Air 240 MicroATX Mid Tower Case  (£71.93 @ Aria PC)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  (£88.16 @ Amazon UK)
Total: £1295.61
Generated by PCPartPicker 2015-02-15 19:42 GMT+0000
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4226672
Total: £1295.61
What are the issues with mounting the H100i, i was hoping to go for 650w PSU but I cant find a reasonable one as I don't plan on SLI in the build. Could you recommend a 650w PSU
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4226836
A few people on here have mentioned mounting problems with the H100i. You might be able to find something with a search. The Corsair link software also has a few niggly issues if you are using Windows 8.1 such as the LED changing colour.
I would look at the XFX XTR 550W if you only plan on a single GTX 970. It is a Seasonic made unit, fully modular and has zero fan mode.
http://www.amazon.co.uk/dp/B00IPD513K/?tag=pcp0f-21
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4226972
If you don't mind me asking, what is you're PC Specs
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4227329
Not as good as your spec  :D
i5 3570K
Gigabyte Z77X-D3H
AMD 7870XT
8GB DDR3
XFX 750W PSU
BeQuiet Dark Rock 2 cooler
Bitfenix Raider Case
It is about 2 years old now but it is still pretty good for what I want.
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4227405
i5 3570K
Gigabyte Z77X-D3H
AMD 7870XT
8GB DDR3
XFX 750W PSU
Do you plan to upgrade anything anytime soon?
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4227513
If I upgrade anything it will be the graphics card and a new case and monitor. Everything else will last Me a while longer yet. I prefer using a Controller over a Mouse and Keyboard as I mainly play RPG/3rd Person Games, so a lot of the time I use the Xbox on My Tv.
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4227625
An air cooler will be quieter and offer good cooling. For the usage described an ssd is a must. It is a touch over budget, but one might consider scraping the storage in this build and replacing it with a 1TB Samsung 850 EVO. .
CPU Cooler: Noctua NH-U14S 55.0 CFM CPU Cooler  (£59.99 @ CCL Computers)
Motherboard: Asus X99-A ATX LGA2011-3 Motherboard  (£187.43 @ More Computers)
Memory: Crucial Ballistix Sport 16GB (4 x 4GB) DDR4-2400 Memory  (£139.99 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£96.97 @ CCL Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£34.45 @ Aria PC)
Case: Fractal Design FD-CA-CORE-3300-BL ATX Mid Tower Case  (£48.99 @ Amazon UK)
Power Supply: SeaSonic EVO Edition 620W 80+ Bronze Certified Fully-Modular ATX Power Supply  (£67.94 @ Scan.co.uk)
Total: £1214.29
Generated by PCPartPicker 2015-02-15 22:20 GMT+0000
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4227967
Total: £1214.29
You suggest getting rid of the HDD and replacing it with a 1tb SSD, I thought you weren't meant to use them as primary storage or am I wrong? I will also further down the line add the 1tb SSD
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4231970
Nothing wrong with using ssd as primary storage. SSD is just more expensive than hdd. But when the budget is there it makes for much faster, quieter, and cooler storage. Programming and web design typically involve working with numerous files and lots of storage i/o. SSD can save a significant amount of time in these tasks.
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4242772
What would you change about my chosen X99 build apart from the RAM because I will be upgrading to 16gb 1 or 2month after I have built it? Also what would you recommend cooling solution wise, Air cooling or Water cooling?
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4243368
I would go with 4x4GB memory from the start. Running single channel negates one of the reasons for going with X99. Adding a second 8GB stick later will not guarantee dual channel operation. One might be stuck running single channel. And, because XMP profiles are based on the kit load, one may not even be able to run memory at the advertised speed and timings.
I would go with air cooling because it is quieter and usually less expensive.
If the budget is tight, I would go with i7-4970K on a Z97 motherboard.
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4243450
Ok, I will go with 4x4gb Ram from the start. The budget isn't tight I just thought I could maybe hold off with 16gb but just to make sure about dual channel operation I will just go with 16gb from get go.
I will go with Air cooling. What do you recommend unit wise, the Cooler Master Hyper 12 Evo or the Noctua DH 15?
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4243513
The DH-15 will block the first PCIe slot on the GA-X99M-GAMING 5 motherboard. I would suggest the NH-U12S it will not have any issues with memory or expansion card slots.
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4243623
Could I not just use the second PCIe slot in the motherboard?
You could. But it means that the cpu cooler would have to be removed if a second gpu were to be added, or in fact any expansion card needing more than 1 lane.
https://linustechtips.com/topic/310940-x99-build-recommendation/#findComment-4245425
