Noctua NH D14 causing some problems
Solved by Colin1337,
Well, I mounted the cpu cooler a little differently. Not as efficient the way I have it (blowing air out the top of the case/sucking air down from the GPU) but so far the computer has been fine. Not a single issue, still able to OC my cpu to 4.7 without cracking 75* C. I'm planning on upgrading to a 980 here soon, so hopefully the heat from the GPU will be less of an issue after that.
