Hello Guys
First off i'm from the UK.
Currently these are the prices of the Xbox One and PS4
XB1 = £399
http://www.argos.co.uk/static/Product/partNumber/1226027.htm
PS4 = £349
http://www.argos.co.uk/static/Product/partNumber/1222540.htm
Now i don't want the G3258 because as per Lnus review this machine will be gaming, but also Light editing and stuff like that, i know this means that this takes it out of the scope of the two consoles but i'd like the extra from this. I don't need windows got that or monitor or keyboard.
Here is the sub £400 build i made
http://uk.pcpartpicker.com/p/hMRy3C
Does anyone have any suggestions or improvements? or complete new open to that haven't bought anything yet?
I'd like a little future proof hence the fm2+ for AMD's 2015 APU lineup
Please help
https://linustechtips.com/topic/310122-xbox-oneps4-topper-machine/
For 900p with medium/high settings it will be enough, altough i would recommend to up the budget a little and get an 860k and a 265 or a 270
For example:
CPU: AMD Athlon X4 860K 3.7GHz Quad-Core Processor  (£56.04 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£25.70 @ Amazon UK)
Motherboard: Gigabyte GA-F2A88XM-D3H Micro ATX FM2+ Motherboard  (£53.86 @ Scan.co.uk)
Memory: Team Vulcan 8GB (2 x 4GB) DDR3-2133 Memory  (£54.90 @ Overclockers.co.uk)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£34.45 @ Aria PC)
Video Card: Sapphire Radeon R7 265 2GB Video Card  (£109.99 @ Amazon UK)
Case: Cooler Master N200 MicroATX Mid Tower Case  (£35.04 @ Scan.co.uk)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.79 @ Aria PC)
Other: MOBO Flash and delivery  (£17.48)
Total: £437.25
Generated by PCPartPicker 2015-02-14 09:48 GMT+0000
This wil give alot better performance in games
Edit: this build wil give you 1080p at med-high settings at +- 60fps
Let's agree to disagree
It's a bit more expensive but it's much much better then your build , get this one you won't regret it. PCPartPicker part list: http://uk.pcpartpicker.com/p/JqQYqs
Video Card: Asus Radeon R9 270 2GB DirectCU II Video Card  (£119.98 @ Amazon UK)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£39.63 @ Amazon UK)
Total: £411.38
Mainboard:ROG-STRIX-B360-G-GAMING/Cpu:I5 8400 /Gpu: Galax RTX 2070 /Ram: Corsair Vengeance 16 GB DDR4/ Storage:1TB HDD 2 Corsair SSD PSU : Corsair 550W/Cooling: Silverstone Air Cooler/ / Case : Corsair/Keyboard:Razer Chroma TKL/Mouse:Mionix Castor+Steelseries Qck Mass/Headphone:V Moda M100
Quote me if you when me to reply to something.
Could you suggest a build?? wouldn't i need a gpu to game in the beginning? Hate not having alot of money
http://uk.pcpartpicker.com/p/2DTRyc
you can game a little bit on the i3, its not super great, but acceptable. after a while, when you have the money for it, get at least an 750ti or comparable card, that should be relative good for the money
Intel 3570k 3,4@4,5 1,12v Scythe Mugen 3 gigabyte 770     MSi z77a GD55    corsair vengeance 8 gb  corsair CX600M Bitfenix Outlaw 4 casefans
I still reccomend the g3258 thought it's the best budget gpu out there right now. Check out this video and see for yourself
What is the difference between z97 and z87?? also this is dual core and most games are now quad core??/
For example:
Total: £437.25
I see, i could lower the ram speed and save £10 ther also is 5001 needed? or can i go 'normal' psu not modular??
Edit;-
do want to play games like watch dogs and battlefield 4
Edit;-
you might have to lower settings for those games...
sorry mate, ment to select
http://uk.pcpartpicker.com/part/msi-motherboard-z97pcmate
the newer z97 has support for the devils canyon haswell refresh CPU's. i reccomend getting the newest chipset
Thats brilliant can you look at my rework?
http://uk.pcpartpicker.com/p/YmKRyc
You'll also need an OS and mouse/keyboard for a desktop.
Seriously, save up a little more and get an i3 or even i5.
I have windows 8.1 copy i got given by a friend mouse and keyboard are sorted i have a wireless mouse i got and a standard keyboard
thats a good, balanced build imo, it should last quite some time, and if fps start to drop a bit, think about getting a new gpu first, because CPU's are usually not the weakest part of a PC
oh, and if you think its too loud, consider getting an aftermarkted cooler for the CPU, the GPU should be pretty quiet, since its an efficient GPU that uses little electricity
the only thing that did worry me is dual core
Most stuff doesn't use more than 2 threads, and its hyperthreaded
But isn't most games being developed for 4 cores?
they say they are, but in reality, not really
