i will start of saying sorry for bad english
my problem is that i try to get or familys old pc to work, but when i plug it to power it makes an really high beep noise over 100 db and then it stops. then i pressed the start butten on the pc and it just continues. i dont know what is wrong but i can not smell any smoke or stuff but i am still to afraid to let it run as i am pretty sure the bib sound is a warning. i hope somebody can help
the pc i do not know much about other than it has
intel dueo
gt 8800
375 watts psu
and 4 ram sticks i dont know if its 4x1 gb or 4x2 gb
hope that somebody can help me:)
https://linustechtips.com/topic/309611-my-pc-will-not-boot/
intel dueo
gt 8800
375 watts psu
Most likely bad PSU or dead motherboard.
https://linustechtips.com/topic/309611-my-pc-will-not-boot/#findComment-4208471
Abdul201588
do you have any whay that i can test it ?
@mads1997 Do you have another PSU or similar cpu socket motherboard? if so, try and swap them out.
https://linustechtips.com/topic/309611-my-pc-will-not-boot/#findComment-4208512
no i dont have any thing similar to the pc:( but thanks anyway :)
The PC is old. I think it's time to upgrade. :P
https://linustechtips.com/topic/309611-my-pc-will-not-boot/#findComment-4208661
