Hey all, I am currently working on a pathfinding program and have run into a small problem. Basically, the code all works as it is supposed to but I was trying to put some of the code into a function rather than have it in code, but it is causing a memory leak. It probably has to do with my parameters and the function call but could use some other eyes. Any idea what I am doing wrong?
#include <iostream>#include <string>#include "tile.h"using namespace std;//nodestruct nodeType{	Tile *tile;	nodeType *link;	nodeType *prevLink;	nodeType();	~nodeType();};//size of mapconst int SIZE = 10;//prototypesvoid findPath(char map[SIZE][SIZE]);void findStartAndEnd(int&, int&, int&, int&, char map[SIZE][SIZE]);void printMap(char map[SIZE][SIZE]);void deleteList(nodeType *list);void searchOpenList(nodeType *list, nodeType *&lowestNode);bool notInList(nodeType *list, int x, int y);void mapOutPath(char map[SIZE][SIZE], Tile *tile);void newTileCreation(Tile *&tile, nodeType *&newNode, int &currX, int &currY, int &endX, int &endY, nodeType *&currentNode, nodeType *&openListTail);int main(){	char end;	string blank;	char map1[SIZE][SIZE] = {{' ','S',' ',' ',' ',' ',' ',' ',' ',' '},							{'B','B','B',' ','B','B','B','B','B',' '},							{' ',' ',' ',' ',' ',' ',' ',' ',' ',' '},							{'B','B','B','B','B','B','B','B',' ','B'},							{' ',' ',' ',' ',' ',' ',' ',' ',' ',' '},							{' ',' ',' ',' ',' ',' ','B','B','B','B'},							{' ',' ',' ',' ',' ','B','B',' ',' ',' '},							{' ',' ',' ',' ','B',' ','B',' ',' ',' '},							{' ',' ',' ',' ',' ',' ','B',' ',' ',' '},							{' ',' ',' ',' ',' ',' ',' ',' ',' ','E'}};	char map2[SIZE][SIZE] = {{' ','S',' ',' ',' ',' ',' ',' ',' ',' '},							{'B','B','B','B','B','B','B','B','B',' '},							{' ',' ',' ',' ',' ',' ',' ',' ',' ',' '},							{'B','B','B','B','B','B','B','B',' ','B'},							{' ',' ',' ',' ',' ',' ',' ',' ',' ',' '},							{' ','B','B','B','B','B',' ',' ',' ',' '},							{' ',' ',' ',' ',' ','B',' ',' ',' ',' '},							{' ',' ',' ','B',' ','B','B','B','B','B'},							{' ',' ',' ','B',' ',' ',' ',' ',' ',' '},							{' ',' ',' ','B','B','B',' ',' ',' ','E'}};	char map3[SIZE][SIZE] = {{' ','S',' ',' ',' ',' ',' ',' ',' ',' '},							{'B','B','B','B','B','B','B','B','B',' '},							{' ',' ',' ',' ',' ',' ',' ',' ',' ',' '},							{'B','B','B','B','B','B','B','B',' ','B'},							{' ',' ',' ',' ',' ',' ',' ',' ',' ',' '},							{' ','B','B','B','B','B',' ',' ',' ',' '},							{' ',' ',' ',' ',' ','B',' ',' ',' ',' '},							{' ',' ',' ','B',' ','B','B','B','B','B'},							{' ',' ',' ','B',' ','B',' ',' ',' ',' '},							{' ',' ',' ','B','B','B',' ',' ',' ','E'}};	//------------------------------------------------------	cout << "\n\t---------------"		 << "\n\t     MAP 1"		 << "\n\t---------------";	printMap(map1);	cout << "Press enter to find path...";	getline(cin, blank);	findPath(map1);	//------------------------------------------------------	cout << "\n\t---------------"		 << "\n\t     MAP 2"		 << "\n\t---------------";	printMap(map2);	cout << "Press enter to find path...";	getline(cin, blank);	findPath(map2);	//------------------------------------------------------	cout << "\n\t---------------"		 << "\n\t     MAP 3"		 << "\n\t---------------";	printMap(map3);	cout << "Press enter to find path...";	getline(cin, blank);	findPath(map3);	//------------------------------------------------------	cout << "Enter a character and press enter: ";	cin >> end;	return 0;}//###########################################################void findPath(char map[SIZE][SIZE]){	// Coordinate Variables	int startX, startY;	int endX, endY;	int currX, currY; 	// Other Variables	bool foundDestination = false;	// New and Current Pointers	Tile *newTile;	Tile *currentTile;	nodeType *newNode;	nodeType *currentNode;	// List Pointers	nodeType *openListHead = NULL;	nodeType *openListTail = NULL;	nodeType *closedListHead = NULL;	nodeType *closedListTail = NULL;	//-----------------------------------------------	findStartAndEnd(startX, startY, endX, endY, map);	//Staring tile and node	newTile = new Tile(startX, startY, endX, endY);	newNode = new nodeType;	newNode->tile = newTile;	//set openlist head and tail to starting node	openListHead = openListTail = newNode;	openListHead->prevLink = NULL;	//search nodes	do	{		//determine open list head		searchOpenList(openListHead, currentNode);		currentNode->tile->getCoords(currX, currY);		//determine if space is searchable, if useable, create new tile and set links		if (currX+1 < SIZE && map[currY][currX+1] != 'B' && notInList(openListHead, currX+1, currY) && notInList(closedListHead, currX+1, currY))		{			newTileCreation(newTile, newNode, currX, currY, endX, endY, currentNode, openListTail);			/*			newTile = new Tile(currX+1, currY, endX, endY, currentNode->tile->getScore() + 1, currentNode->tile);			newNode = new nodeType;			newNode->tile = newTile;			openListTail->link = newNode;			openListTail->link->prevLink = openListTail;			openListTail = openListTail->link;			*/					}		else if (currY+1 < SIZE && map[currY+1][currX] != 'B' && notInList(openListHead, currX, currY+1) && notInList(closedListHead, currX, currY+1))		{			newTileCreation(newTile, newNode, currX, currY, endX, endY, currentNode, openListTail);			/*			newTile = new Tile(currX+1, currY, endX, endY, currentNode->tile->getScore() + 1, currentNode->tile);			newNode = new nodeType;			newNode->tile = newTile;			openListTail->link = newNode;			openListTail->link->prevLink = openListTail;			openListTail = openListTail->link;			*/					}		else if (currX-1 >= 0 && map[currY][currX-1] != 'B' && notInList(openListHead, currX-1, currY) && notInList(closedListHead, currX-1, currY))		{			newTileCreation(newTile, newNode, currX, currY, endX, endY, currentNode, openListTail);			/*			newTile = new Tile(currX+1, currY, endX, endY, currentNode->tile->getScore() + 1, currentNode->tile);			newNode = new nodeType;			newNode->tile = newTile;			openListTail->link = newNode;			openListTail->link->prevLink = openListTail;			openListTail = openListTail->link;			*/					}		else if (currY-1 >= 0 && map[currY-1][currX] != 'B' && notInList(openListHead, currX, currY-1) && notInList(closedListHead, currX, currY-1))		{			newTileCreation(newTile, newNode, currX, currY, endX, endY, currentNode, openListTail);			/*			newTile = new Tile(currX+1, currY, endX, endY, currentNode->tile->getScore() + 1, currentNode->tile);			newNode = new nodeType;			newNode->tile = newTile;			openListTail->link = newNode;			openListTail->link->prevLink = openListTail;			openListTail = openListTail->link;			*/					}		else		{			if (currentNode == openListHead)			{				openListHead = openListHead->link;				if (openListHead != NULL)					openListHead->prevLink = NULL;			}			else if (currentNode == openListTail)			{				openListTail = openListTail->prevLink;				openListTail->link = NULL;			}			else			{				currentNode->prevLink->link = currentNode->link;				currentNode->link->prevLink = currentNode->prevLink;			}			currentNode->link = NULL;			currentNode->prevLink = NULL;			if (closedListHead == NULL)				closedListHead = closedListTail = currentNode;			else			{				closedListTail->link = currentNode;				closedListTail = closedListTail->link;			}		}		newTile->getCoords(currX, currY);		if (currX == endX && currY == endY)		{			currentTile = newTile;			foundDestination = true;			break;		}	} while (openListHead != NULL);	if (foundDestination)	{		mapOutPath(map, currentTile);		printMap(map);	}	else		cout << "\n\t\t\t------------------"			 << "\n\t\t\t  No Path Exists"			 << "\n\t\t\t------------------\n\n";	deleteList(openListHead);	deleteList(closedListHead);}//###########################################################void findStartAndEnd(int &xStart, int &yStart, int &xEnd, int &yEnd, char map[SIZE][SIZE]){	for (int i = 0; i < SIZE; i++)	{		for (int j = 0; j < SIZE; j++)		{			if (map[i][j] == 'S')			{				xStart = j;				yStart = i;			}			else if (map[i][j] == 'E')			{				xEnd = j;				yEnd = i;			}		}	}}//###########################################################void printMap(char map[SIZE][SIZE]){	cout << "\n\t\t-";	for (int k = 0; k < SIZE; k++)		cout << "----";	cout << endl;		for (int i = 0; i < SIZE; i++)	{		cout << "\t\t|";		for (int j = 0; j < SIZE; j++)		{			cout << " " << map[i][j] << " |";		}		cout << "\n\t\t";		if (i == (SIZE - 1))		{			cout << "-";			for (int k = 0; k < SIZE; k++)				cout << "----";		}		else		{			cout << "|";			for (int k = 0; k < SIZE; k++)				cout << "---|";		}		cout << endl;	}}//###########################################################void deleteList(nodeType *list){	nodeType *currNode;	while (list != NULL)	{		currNode = list;		list = list->link;		delete currNode;	}}//###########################################################void searchOpenList(nodeType *list, nodeType *&lowestNode){	lowestNode = list;	int lowestCost = list->tile->getCost();	int tempCost;	list = list->link;	while (list != NULL)	{		tempCost = list->tile->getCost();		if (tempCost <= lowestCost)		{			lowestNode = list;			lowestCost = tempCost;		}		list = list->link;	}}//###########################################################bool notInList(nodeType *list, int x, int y){	int tempX;	int tempY;	while (list != NULL)	{		list->tile->getCoords(tempX, tempY);		if (tempX == x && tempY == y)			return false;		else			list = list->link;	}	return true;}//###########################################################void mapOutPath(char map[SIZE][SIZE], Tile *tile){	int x, y;	tile->getParent(tile);	do	{		tile->getCoords(x, y);		if (map[y][x] != 'S')			map[y][x] = 'X';		tile->getParent(tile);	} while (tile != NULL);}//##########################################################//new Tile functionvoid newTileCreation(Tile *&newTile, nodeType *&newNode, int &currX, int &currY, int &endX, int &endY, nodeType *&currentNode, nodeType *&openListTail){	newTile = new Tile(currX+1, currY, endX, endY, currentNode->tile->getScore() + 1, currentNode->tile);	newNode = new nodeType;	newNode->tile = newTile;	openListTail->link = newNode;	openListTail->link->prevLink = openListTail;	openListTail = openListTail->link;}//##########################################################// nodeType constructornodeType::nodeType(){	tile = NULL;	link = NULL;	prevLink = NULL;}//##########################################################// nodeType destructornodeType::~nodeType(){	delete tile;	}
The problem is with the newTileCreation at line 346, the calls are on 131, 144, 157, and 170
https://linustechtips.com/topic/30947-c-pathfinding-problem/
