So I'm looking for a USB hub to go ontop of my desk. So I need the cord to be around 1 metre - 4 feet long, a bit longer doesnt matter, but can't be shorter than 1 metre. I'm going to have this ontop of my desk.. so asethtics will matter to me. I'll need at least 4 usbs, maybe 6. Anyone have recommendations? Or is there a way to DIY from salvaging the usb port from old computer cases?
https://linustechtips.com/topic/308892-usb-hub/
Well that's very generic. I'd recommend a USB 3.0 hub, as you never know when in the future you might be plugging in USB 3 devices into those hubs.
As far as length you could always get a USB extension cord. Just make sure that if you're using a USB 3.0 hub that you get a USB 3.0 extension cable.
"Rawr XD"
https://linustechtips.com/topic/308892-usb-hub/#findComment-4198309
http://www.amazon.com/Sabrent-4-Port-Individual-Switches-HB-UMLS/dp/B00BWF5U0M/ref=sr_1_1?ie=UTF8&qid=1423713868&sr=8-1&keywords=usb+hub
Its cheap and I got two of them. You can run your keyboard and mouse and wifi on one of them. I charge other things with the other. But I noticed that you can only charge one thing at a time. But its easy to switch one and off what you want to charge.
https://linustechtips.com/topic/308892-usb-hub/#findComment-4198329
Sounds good. Any reccomendations? While I'm at it.. does anyone know where to get a good quality headphone splitter? The ones I buy at the dollar store are awful.. sometimes one side of the headphone plays no sound unless I move it in a different angle/ rotate the connector..
https://linustechtips.com/topic/308892-usb-hub/#findComment-4198331
Yeah with a non-powered hub you can only charge one thing off of it at one time. If you want to charge multiple things I'd suggest a powered hub, such as this one
http://www.amazon.com/AmazonBasics-Port-2-5A-power-adapter/dp/B00DQFGH80/ref=sr_1_1?ie=UTF8&qid=1423714012&sr=8-1&keywords=usb+3.0+powered+hub
"Rawr XD"
https://linustechtips.com/topic/308892-usb-hub/#findComment-4198346
Probably wont be charging more than one thing. I only have an iPhone and I only charge that on my computer 3 - 4 times a week.. the rest being by my bed when im snoozing
https://linustechtips.com/topic/308892-usb-hub/#findComment-4198363
Hmm
Then http://www.amazon.com/Anker%C2%AE-AH400-4-Port-Compact-Built-/dp/B00B7FOQCK/ref=sr_1_3?ie=UTF8&qid=1423716405&sr=8-3&keywords=usb+3.0+hubor http://www.amazon.com/dp/B00DQ5RYP0?psc=1
"Rawr XD"
https://linustechtips.com/topic/308892-usb-hub/#findComment-4198601
It does have the plug in for a power cord though. But it didnt come with one. Do you know where I could get one?
https://linustechtips.com/topic/308892-usb-hub/#findComment-4203561
