Wow man, that really sucks. You must've gotten a faulty board, and overclocking the CPU forced the faulty component into overdrive, forcing bad voltage into it.
That is an excellent motherboard, however not all are perfect all the time, errors can occur. However, I feel that you might want to look into your power supply, if the 12V rail becomes faulty, then the motherboard cannot regulate the CPU as effectively. If you get the replacement motherboard and CPU and the problem persists, it may be your PSU.
| CPU: Intel i5 3570K @ 4.4GHz 1.26v | GPU: AMD R9 290X @ 1090MHz |
| RAM: 2x4GB Samsung Green @ 2133MHz OC |
| PSU: Corsair RM850 | Case: Fractal Design Define R4 |
set up your gear on a testbench(motherboard box) pull the psu and water cooler...yes.
start testing with one video card and one stick of ram.
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
Thanks guys.
But once I removed my CPU it revealed like 4 bent pins.. Even though I installed my CPU perfectly. The mobo came with like 2 damaged pins and I just moved them and it seemed alright.
I already am sending the CPU soon after I stop by the post office, and i'm going to contact my seller about the mobo so they can give me a replacement.. Or I'll file an A-Z claim on Amazon and get my money back since it came damaged.
