Sorry ive been posting this question twice. But is there a way to transfer my steam saves to an external hard drive? all i want is to save my borderlands2 characters to an external drive because i am getting a new computer. I have put a lot of time into these characters and would hate to lose them.
Note: Taking my hard drive out is not an option. I am reseting my computer to factory settings because i am selling it.
https://linustechtips.com/topic/308276-please-help-again/
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189689
So if i put those files on an external hard drive, then i will be able to put them back onto steam When i get my new pc?
Yep, it should work.
There are some save files in %Addata%, only for some games though.
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189708
Where would i find my borderlands save files and character saves?
Mine are in My Documents and in My Games
CPU i5 3570k MOBO Asus Maximus Gene V GPU Asus DCUII 670 CASE Corsair 350D (windowless) SSD Crucial M550 256GB msata CPU COOLER Noctua NH-D14 RAM Corsair XMS3 8GB 1600mhz PSU Corsair AX750 Display Asus PB287Q 4K (my review on it http://linustechtips.com/main/topic/380533-journey-into-4k-goodness-asus-pb287q-review/) & Asus VH236H 1080P
Keyboard Logitech G710+ MX Brown Mouse Logitech G502 (my review on it http://linustechtips.com/main/topic/299464-logitech-g502/ )
Proud owner of a BlackBerry Q10.
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189720
Its all saved in the cloud. Youll be able to sync your characters on your new computer.
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189730
Are you sure its saved to the cloud? Is there a way to check? And how do i re-download them from the cloud when i get my new pc? Sorry i just really dont wanna lose these characters.
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189746
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189764
it always backups your saves. just download the game again and it will automatically detect if you have saves for that game available in the cloud.
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
https://linustechtips.com/topic/308276-please-help-again/#findComment-4189891
