so i just got my second monitor, webcam, and my microphone i plan on using for twitch setups however i want to maximize my setup I currently have the two monitors at a slight angle so they make a soft  inward v, should i have them be in line with each other or in your experience have you found, it better to have them angled inward? also what should the ideal position for my Microphone be? i.e. how far from my mouth etc, its on a boom stand and is a audio technica at220 usb  with goose neck pop filter attached to the boom stand , i have a Logitech webcam atop the right of my monitors and 2 of the 5 speakers of the Logitech 5:1 speakers behind each monitor  with the fifth on top of the left monitor.any  feed back will be appreciated as im trying to get my setup ready and then work on my bods setup later this evening , if you think a picture would be better let me know and ill get one taken.
Its a Championship not a Belt!
https://linustechtips.com/topic/307990-setting-up-desk-layout-tips/
annd now i need to figure out how to put my photos from my comp onto the forum.
really? upload to puush or imgur and link in your post.
"The of and to a in is I that it for you was with on as have but be they"
ive never had to upload a photo to the forum, and Ive never used either of those sites, i think i found out how to do this tho.
I like to keep my setup minimal, so I wouldn't overcrowd it IMO :)
well i know i need my two monitors for twitch, so i can keep my chat in one and game play in other, then the mic and webcam are needed, and so are speakers because sound, so......
