Unstable Vcore Voltage help?!
Go to solution Solved by Queek,
@TakeToTheShadows Software monitoring of voltages are almost always incorrect at idle.  They are more accurate at load.  If your system isn't crashing, don't worry about those voltages.
I just finished building a new gaming rig and I'm just in the middle of setting everything up but I noticed AIsuit giving me warning popups about my Vcore voltage which I Asume is CPU related and I looked online and saw people saying that AIsuit stats are sketchy and just to disable them so I did but I noticed in HWiNFO it also says my Vcore voltage is anywhere between 0.000v to 1.120v
post-187553-0-63523800-1423526654_thumb.
And constantly changing and then I saw people saying it should be almost completely stable so that kinda got me worried :/ My CPU is a i5 4690k with a NZXT Kraken x61 cooler and a Asus Sabertooth Mark2 Mobo. Someone please help I really want to start benching my new hardware but I don't want to put it under load if there's something wrong or it's not stable! :/
https://linustechtips.com/topic/307623-unstable-vcore-voltage-help/
voltage looks pretty normal to me
Mainboard Asrock Z170 OCF CPU 6700k RAM Tridentz 3600 HDD Intel 730 240gb GPU GTX 780ti sc acx PSU Silverstone Strider 1200W  Case Antec 900 Laptop Lenovo Thinkpad T520 build log-   http://linustechtips.com/main/topic/35809-antec-900-the-re-birth-of-a-legend/ Check out the Tech Center https://www.youtube.com/user/prokon24/videos LTT's Unicore King
If it was actually reading 0v your CPU wouldn't be on. Try using a different monitor like AIDA64 or HWMonitor.
@ProKoN I believe he's talking about the Vcore#0-3 values, which do look a bit wonky. Cache voltage looks perfectly fine.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
Isopropyl alcohol is all you need for cleaning CPU's and motherboard components.  No, you don't need [insert cleaning solution here].  -Source: PhD Student, Chemistry
Why overclockers should understand Load-Line Calibration.
ASUS Rampage IV Black Edition || i7 3930k @ 4.5 GHz || 32 GB Corsair Vengeance CL8 || ASUS GTX 780 DCuII || ASUS Xonar Essence STX || XFX PRO 1000W
