GTX 970 FPS Issue
Alright so I've figured out what the issue is. I closed nearly everything on my desktop, and found (using MSI afterburner stats) that GPU usage was still at 98%, whilst 'nothing' was happening. So I went into task manager and found the culprit, something called "Steam (32 bit)" not to be confused with the popular games platform with the same name. I know this for a fact because I don't use steam. I looked online and found that it has something to do with NVIDIA's auto-update process? can anyone confirm?
UPDATE: I found this: https://forums.geforce.com/default/topic/791439/i-think-my-gtx-770-is-overheating/?offset=21
So apparently it is malware that has to do with bitcoin mining, how do I get rid of it?
UPDATE: I cleared my PC of the steam malware and managed to fix the FPS performance issue. Thanks for all the help ![]()
