Node 304 Air cooling
Go to solution Solved by MeltingPoint,
I'm worried mostly about having to remove the hard drive cages, which i absolutely need. Would it be an issue do you think?
You only need to remove 1 cage if you plan to install a graphics card. Other than that, all cages can stay without interfering with anything.
Quick question:
I'm thinking of moving from my prodigy to the smaller Fractal Node 304, and i'm wondering what's the largest air cooler i could fit in.
I'm looking at the Dark Rock 3, but i'm not sure it'll fit. If not, i'm thinking of just getting the Shadow Rock Slim
My mobo is a p8z77i deluxe too.
Thanks!
https://linustechtips.com/topic/307013-node-304-air-cooling/
Coolers up to 165mm should fit.
What matters is the position of the CPU socket on the board. By the looks of it, your mobo has good socket positioning.
The Dark Rock 3 should fit in the Node 304. On some motherboards, even the huge NH-D14 fits in the tiny case. Heck, even the monster Cryorig R1 fits in there as well.
If the link doesn't work, just search on google images "node 304 cryorig r1"
I have the Gelid Black Edition cooler in my node 304 and it fits as well.
60FPS Microwave
Intel Core i5-4670K | Galax GTX 970 EXOC | ASRock Z97E-ITX/ac | Team Elite 8GB 1600MHz | Gelid Black Edition | Samsung slowdown + WD Blue 1TB x2 | Cooler Master V550 | Corsair K65 + Logitech G100s | MasterCase Pro 3
https://linustechtips.com/topic/307013-node-304-air-cooling/#findComment-4171309
60FPS Microwave
https://linustechtips.com/topic/307013-node-304-air-cooling/#findComment-4171373
