Hi guys Im recently getting very high temps(see screenshot) on my CPU. its at 4.5ghz and cooled by a Corsair H80 with 2 noctua NFF12 fans.
is this normal temps for that kind of overclock
CPU: i5 3570k
Cooler: Corsair h80 (about 3 years old now)
CPU frequency:4.52ghz
Volts: 1.3volts (any lower it just blue screens)
post-6162-0-33644300-1423330590_thumb.jp
im gonna have to turn the overclock down for now i think.
My PC specs are CPU: 6700k @4.7Ghz Ram: 16GB Corsair RGB Pro GPU: RTX 2070  PSU: RM650 CPU cooler: corsair H150 Case: corsair Motherboard: ASUS Z270 Pro SSD: 1tb Samsung 970 EVOand SK Hynix 1TB
https://linustechtips.com/topic/306174-excessive-temps-100c-on-cpu/
I read that the tool you are using just increases the temps so much, try prime95 or aid64.
  ﷲ   Muslim Member  ﷲ
KennyS and ScreaM are my role models in CSGO.
CPU: i3-4130 Motherboard: Gigabyte H81M-S2PH RAM: 8GB Kingston hyperx fury HDD: WD caviar black 1TB GPU: MSI 750TI twin frozr II Case: Aerocool Xpredator X3 PSU: Corsair RM650
its getting around 80-90c in games
I would unscrew the cooling block and reapply thermal paste and resit the cooling block. If that does not help, just turm down your overclock. If you are only gaming, that wont change anything
Cpu:i5-4690k Gpu:r9 280x with some other things
Maybe you should go to BIOS reset to default(You can oc after everything's normal),and take down your cpu aio cooler,hold the radiator and shake a bit to see if there's any liquid inside,maybe it's dry out.
If not,reapply thermal paste see if temperature drops.
I should stop using the Computer at those temps! wat does the bios say about the cpu temps?
Troubleshooting
1 Bios reset
2 unscrew the fan of the cpu and place it back up
3 apply new paste
4 Undo software OC and test again
5 clean the computer maybe dust
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
