I use my 32gb Toshiba flash drive for installing windows 8.1 for my new PC
and it work perfectly
after that, i want to use my flash drive for my dvd player to watch my movies
so i format it to ntfs and my dvd cannot read it
so i format it again to fat32
the dvd player can read my flash drive but weeks later, when i copied my movies to the flash drive
the speed is only hitting 5-8mb/s
how to fix this ?
i plug it in on USB 3.0
https://linustechtips.com/topic/306046-flash-drive-becomes-slow/
Terve!
I would recommend using crystaldisk benchmark to run a benchmark.
If it is slow in the benchmark as well, I think it is a short time before failure.
How old is your flash drive?
There is an other benchmark that tells you more about your drive, but I cannot remember the damned name.
I hope I can give you the other software's name.
Sayonara!
https://linustechtips.com/topic/306046-flash-drive-becomes-slow/#findComment-4167682
