I just installed windows 8 and i had some updates. I installed all of the 130 updates then it said i needed to restart computer. When i am starting up again it says
Failure configuring Windows updates. Reverting changes. Do not turn off computer "
I had this on over night but when i woke up i was at desktop again. Then i checked windows update and all of the 130 updates failed installing. Now i can't install updates without this happening again. If you know how to fix it please help me
https://linustechtips.com/topic/305985-update-loop-please-help/
you need to clear your windows update temp files.
Delete the content in the following 2 folders.
C:\Windows\SoftwareDistribution\Datastore
C:\Windows\SoftwareDistribution\Download
Reboot, Then run windows update again.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
https://linustechtips.com/topic/305985-update-loop-please-help/#findComment-4163322
