Howdy people~
I run a small broadcasting crew for the school that I go to, and I've been trying to come up with a solution for running a more mobile camera that can stream to our PC wirelessly(spelling?) to be used as a video source, probably through a capture card of some kind.
At the moment, we use a really really long cable and hope no one trips, but I was hoping for a more professional solution.
I have found one item that looks like it might work, but I cant find a price for it and It looks like I'd have to pay an import fee anyways. I live in the US, and I'm hoping to find some kind of solution that I could order from within the country.
Link:
http://www.link-mi.hk/products/Wireless%20HDMI/251136627621.html
Thanks for the help!
https://linustechtips.com/topic/305851-wireless-hdmi/
Howdy people~
Link:
Wireless HDMI is certainly something you should avoid if at all possible.
Something that would be helpful is: what camera are you using?
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/305851-wireless-hdmi/#findComment-4157218
Howdy people~
Link:
do your camera have some kind of wireless capability?
for example, I'm using ezcast to stream anything that show up at my phone directly to my tv
https://linustechtips.com/topic/305851-wireless-hdmi/#findComment-4158255
