I have an ASUS X99 Deluxe that I am very happy with.  Is there any way to disable the power to usb peripherals when the system is off?  I have a DAC and USB mic which both have LED’s that will stay on unless I unplug them.  I have searched through the BIOS with no luck, any suggestions?
https://linustechtips.com/topic/305818-disable-usb-power/
Wait how can your system be powering your USB hubs when it is off?!?!
Are you using windows 8.1? Off the fast start up option
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/305818-disable-usb-power/#findComment-4156703
