I have a small micro atx case because my PC was originally a budget build but I decided to splurge after I bought the case.  Anyway I have no room for a resevoir or radiator inside the case however my case has dual 120mm fan mounts on the side so I could put my radiator and fans on the outside.  Any ideas for cooling solution.  Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147166
https://linustechtips.com/topic/305798-water-cooling-probs/
That wouldn't be very practical, I recommend getting a new case if you have the money
CPU: i5-6600k @ 4.4GHz | Motherboard: Asus Z170 Pro Gaming | RAM: 8GB HyperX Fury | GPU: Asus Strix GTX 980 | Case: NZXT Noctis 450 Red/Black | Storage: 256GB Sandisk SSD + 1TB Western Digital HDD | PSU: EVGA 750w | Monitor: ASUS VS247H | CPU Cooler: Cooler Master Hyper 212 Evo | Keyboard: $15 Cheapo Rubber Dome Keyboard | Mouse: Rosewill RGM-300
Linus Tech Tips Pebble (and Pebble Time) notifier watchface!
https://linustechtips.com/topic/305798-water-cooling-probs/#findComment-4156455
Consider going with an external solution -- mounting one or more large radiators to the outside of the case. I discussed this on another forum with someone with a small mid-tower that wouldn't provide a lot of radiator options. There are large square radiators available -- 2x3 and 3x3 120mm radiators -- that if you can be a little creative, you might be able to mount one of those to the side of your case. You'll need to figure out how to power the fans, but it'd at least have the radiator taken care of.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
https://linustechtips.com/topic/305798-water-cooling-probs/#findComment-4157173
Le sigh, you can make anything fit with enough imagination, a drill and a dremel. Mount the rad and fans on top of the case, cut 2 holes for the tubing, put the fans under the rad, as for the res, dual bay res combo failing that you could mount a D5 tube res on the outside or buy one that you can lay flat on the floor of the case etc etc blah blah. One thing you must not do is compact watercooling parts in such a way that you end up heating up other components such as a rad on the floor of a case with fans intaking and blowing hot air onto a pump, PSU and a GPU with the PSU wires blocking half the airflow, you're just wasting time and money...
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/305798-water-cooling-probs/#findComment-4157323
I would mount the rads on the top of the case (externally).If you have questions on how to do that just start another thread,we will be more than happy to help you out.
Why start another thread? Give him the information in one spot, nothing worse for someone coming to the site from google to then track down the rest of the infromation (done that more than enough in my time and it could all be solved with info in one thread).
Chernobyl
Kraken
https://linustechtips.com/topic/305798-water-cooling-probs/#findComment-4160648
I specifically said more than enough.
Like? If the case gets modded and then its all in here like a little build log then its easier to read etc, think bout it, imagine reading instructions for something but the pages are all muddled up and not in order.
Chernobyl
Kraken
https://linustechtips.com/topic/305798-water-cooling-probs/#findComment-4160835
