I'm doing a science Fair project and am looking for information regarding what makes a better fan, one airflow optimized or two pressure optimized?
thats depends on what the fan is being used for.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/305546-what-is-better-air/#findComment-4155171
To elaborate:
It depends on where you put it.
If the fan is going on a radiator, which offers resistance, a Pressure optimized fan is key.
Otherwise, for intake/exhaust of a case, Air Flow is where you want it.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/305546-what-is-better-air/#findComment-4155198
To elaborate:
a vague question gets a vague answer. especially when you have multiple threads on the same subject
Rig Specs:
https://linustechtips.com/topic/305546-what-is-better-air/#findComment-4155267
I didn't see any of that, fair enough.
https://linustechtips.com/topic/305546-what-is-better-air/#findComment-4155282
;) its ok. my notification have stopped working for some reason :(
Rig Specs:
https://linustechtips.com/topic/305546-what-is-better-air/#findComment-4155410
To understand this let me make an analogy. You want the air to move as fast as possible, obviously, and you have two scenarios. In one the air flows without any restriction, in the other you are pushing it through a dense fin array which does present some resistance to the air. In the same way, say you want to go as fast as possible with your car. One section is nice and flat so you can use a high gear to let the car go to top speed. Now say you'd want to go up a steep hill as fast as you can. If you used top gear the engine wouldn't have enough torque to keep the car going and you'd slow down and stall, whereas with a lower gear you don't reach the top speed the car would have been capable of on a flat surface, but you can keep going when the going gets tough. Static pressure fans are like that: the blades are angled less steeply and they move less air per revolution than airflow optimized fans in an unrestricted environment, but the more gentle angle of attack makes the airflow less eager to stall when there's stuff in the way so they can exert more pressure to blow the air past the obstacle.
So each type has a purpose. Airflow fans are usually used to ventilate the case with nothing in front of or behind them. To push air through radiators or heatsinks, static pressure optimised fans are more suitable.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
https://linustechtips.com/topic/305546-what-is-better-air/#findComment-4159596
