help with wireless card.
Go to solution Solved by bbrooking18,
How would I know what's compatible with my router?
It should be since wireless is backwards compatible, it will work at the slowest speed, e.g. I have an AC wireless card that came with my mobo and I have a N router so it works at N and if I had an AC router and a N certified card then I would see N speeds most modern routers are a/b/g/n so unless your is very old you should be fine
Im building a decent pc next month and I have no idea about networking cards. Can anyone help? If you need more info let me know I can give you what I can find. Thanks and sorry about the stupidity.
<p>CPU: Intel i7 4790k(4.9GHz), Motherboard: ASUS sabertooth Z97 Mark 1 RAM: Corsair Dominator Platinum 16GB (2 x 8GB) GPU: EVGA GeForce GTX 980 4GB Superclocked ACX 2.0 (2 way SLI) PSU: EVGA 850w G2 Storage: Intel 730 Series 240GB 2.5" SSD, Western Digital Caviar Black 1TB Case: NZXT H440 Designed by Razer, EK,Alphacool,Bitspower custom loop.
“Peace cannot be kept by force. It can only be achieved by understanding.”
Albert Einstein 14 December 1930
https://linustechtips.com/topic/305394-help-with-wireless-card/
cheap ones tend to work well. I have a 15 euro asus PCe N-15, works a charm for me :)
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150839
Intel Core i5 4690K @ 4.2Ghz | Evga GTX 780 Ti SC ACX with backplate | MSI Gaming 9 AC | 8GB (2x4) Corsair Vengeance Pro Silver 2400 MHz | Corsair H105 128GB Crucial MX100 | Toshiba 2TB | Evga 750G2 | Corsair Obsidian 750d | Be Quiet Silent Wings 2 PWM (3x140mm & 3x120mm)
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150852
Tbh i have no idea.. I'm out of my depth in networking, i'v never looked into it. I just assumed that it was standard :L
Lol me too thats why im here. Thanks for the info ill keep in mind.
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150857
Dont know the exact model bit its about 3 year old Motorola. I can check what model in about 20 min when I get home from work.
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150864
When you get home google the model and it's part number should tell all you need to know
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150874
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150882
If you have any other questions post back here either I or somebody else should be able to help you
https://linustechtips.com/topic/305394-help-with-wireless-card/#findComment-4150911
