Water cooling compatibility:
  • Front – 240mm radiator (thick and slim) when HDD cages are removed, radiator cannot exceed 275mm in total length with the ODD bay in place.
  • Top – 240mm or 360mm radiators (thick and slim); the use of 360mm radiators requires removal of the ODD cage.
  • Bottom – 120mm radiators
  • Rear – 120mm radiators
Yeah, you're good with a 360mm rad but I doubt you can fit that XTX there; it's too big.
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
yes, the 65mm XTX will fit in the arc mini R2. you'll have to remove the ODD
cage. a 360 can be used for a CPU/GPU loop. no real voltage overclocking
without sacrificing fan speed (noise) and temperatures.
i've seen a Monsta 360 in an arc mini (couldn't see the CPU).
Well does it look good?or its not advisable got a deal of buying that rad with a pump but dont know if it will look nice
