Is my SSD dying? When i started my pc, it gave me a warning that said theres something wrong with the Windows.exe When i got it to start it froze to desktop. Third time it only gave black screen. I let it be with out power for 5 minutes and tried again, it gave me a warning that said Windows wasn`t recovered properly. I klicked restart anyway and it restarted normally. Now i`m writing this text whit it. What is/was wrong?
https://linustechtips.com/topic/304862-ssd-problem/
I think it was just a glitch. If it works perfectly fine now then nothing to worry about, but if it happens a lot, then let us know.
"Rawr XD"
https://linustechtips.com/topic/304862-ssd-problem/#findComment-4143589
sounds to me like windows is performing as expected
OOH, wow
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
https://linustechtips.com/topic/304862-ssd-problem/#findComment-4147666
