So I drew up a little diagram. Is this the best way. Use your imagination, you should be able to figure out what blob is what.
post-11646-0-12703600-1423092217_thumb.p
Work Desktop | CPU: Intel Core i7 4770k | GPU: Quadro K1200 | Motherboard: EVGA Z97 Classified | RAM: Corsair Dominator Platinum 32GB (4x8GB) DDR3-2133Mhz | PSU: Seasonic 750W SS-750KM3 80 PLUS Gold | STORAGE: WD 1TB Se Enterprise Grade Drive & Corsair Neutron NX500 400GB NVMe PCIe  | COOLER: Enermax Liqtech 240 -  5x Noctua NF-F12 iPPC 2000 PWM | CASE: Corsair 600C | OS: Windows 10 Pro | Peripherals: Logitech MX Master 2S -- Logitech K840 -- INTEL X520 10Gb NIC -- 3x Acer H236HL -- Build Log |
Work Server | CPU: Intel Xeon E5-2650 v3 | Model: Cisco UCS C220 M4 (SFF) | RAM: 64GB (4x16GB) Cisco (Samsung) DDR4 2133Mhz | STORAGE: 4x Cisco (Seagate) 900GB 10K 2.5" (RAID 10) - 2x 32GB Cisco FlexFlash Boot Drive (RAID 1) | OS: vSphere 6.7 Enterprise Plus U3 |
Laptop | CPU: Intel Core i7 6700HQ | GPU: Nvidia GTX 960M 2GB GDDR5 | RAM: 32GB (2 x 16GB) DDR4-2400Mhz | STORAGE: 512GB Hynix NVMe | OS: Windows 10 Pro |
Gaming Desktop | CPU: Intel Core i7 9700K | GPU: Gigabyte RTX 2080 WINDFORCE 8G  | Motherboard: ASRock Z390 PHANTOM GAMING-ITX | RAM: Ballistix Elite 32GB Kit (16GB x 2) DDR4-3000 | PSU: Silverstone SX700-LPT 700w 80 PLUS Platinum | STORAGE: 2x Samsung 970 PRO 1TB NVMe | COOLER: Noctua NH-L12 | CASE: Louqe Ghost S1 | OS: Windows 10 Pro | Build Log in Progress |
Home Server | CPU: Intel Xeon E5-2690 (Sandy Bridge) | GPU: Quadro P2000 | Motherboard: SUPERMICRO X9SRL-F  | RAM: 64GB (8x8GB) Micron VLP DDR3-1600 ECC | PSU: SUPERMICRO 665W 80 PLUS Bronze | STORAGE: 2x Samsung 860 EVO 500GB (RAID 1) - 4x WD 8TB Ultrastar (RAID 10) - Intel SSD D3-S4510 Series 240GB (BOOT)  | COOLER: Noctua NH-U12DXi4 with 2x Noctua NF-F12 iPPC 3000 PWM | CASE: SUPERMICRO CSE-842TQ-665B 4U | OS: vSphere 6.7 Enterprise Plus U3 | Build Log in Progress |
| Pixel 4XL 128GB - Clearly White - Unlocked - Carrier: Visible |
| F@H STATS |
https://linustechtips.com/topic/304485-tube-running-confusing-need-help/
Personally I think Water Closet runs are terribly messy.
Looks fine, but I think the front radiator flow directions are switched; its both receiving and sending water into the reservoir.
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
mmm, don't believe you'll get the front and floor radiator to co-exist too well. the
clearances there are so close. if thats a 280, then deffo not going to fit. if it is
a 240 (short) then the floor rad (30mm with one fan set) will fit.
a 360x 45 in the roof and 240x 60 in the front intake or floor (best option with
a filter) will hold your fan speed sub 1100 rpm easily with overclocking with high
voltages. if planning on 2x GPU, then the voltage will need to be lower or fan
speed should be increased.
lastly, the basement with a rad inside will not be a best option as the heated air
has no place to exhaust.
Yeah, most of that is covered. The reason they're are thin rads. (I Believe they're all 30mm) is because I want white ones and those were the only ones I could find unless I painted some black ones.
21mm Core, 40mm thick
| F@H STATS |
I've built two loops into the 750D and you used a tube layout similar to how I originally tubed up my wife's build (see my signature for links to build logs).
A couple things to point out on the 750D for mounting a front radiator and still allowing for a bottom radiator. First, the front radiator should be a 240mm at most, and you're going to want to mount it using the vent holes in the front area. You'll see that the holes marked "120" and spaced for a 240mm radiator line up with other holes in the front. If you want to fit a 240mm radiator on the bottom of the case, you'll need to use those holes for mounting the radiator, something I point out here. You'll also end up with the front 140mm fans directly over the radiator.
On the bottom radiator, that will only work if you're using a short power supply. My wife's RM1000 (180mmlong) barely fits with the bottom radiator, but my AX860 plays nicer.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
alphacool offers white rads. some specialty shops offer painting services, too.
or paint the black ones.
Alphacool does offer white rads which would work great until I got to the top 360mm rad in which case I think it would push against my CPU power cables.
| F@H STATS |
their XT45 360 fits just fine in the stock location or if your cut the ODD bays out
then the UT60 360 fits with dominator platinums and the 8-pin is no issue.
They don't have a white XT45
| F@H STATS |
