You can get some Rosewill Hyperborea fan!, They are rebranded Akasa fans, and are very silent while keeping the cost down.
There's no 'very silent'. Something is either silent or it isn't. Hyperboreas are quiet but far from silent.
Noctua iPPC's aren't quiet.
Each brand has their quiet fans. In terms the quietest fans from each brand:
NF-s12a < Silent Wings 2 < Some oem Cougar fan that I forgot the name of < Aerocool DS and AF120 QE's trade blows depending on where they're positioned
Noise Blocker, Noctua, Be quiet. Fans wont affect a heatsink that much unless they have a higher static pressure.
The fan on a heatsink definitely affects its performance. There just aren't many quiet fans that perform as well as the 212 Evo's stock blademaster.
https://linustechtips.com/topic/303873-quiet-case-fans/#findComment-4130260
Deep Silence Aerocool fans are reasonable quiet and good looking (if that matters to you)
<---Have a couple 140mm red led in my NZXT H440
CPU i5-4690K(OC to 4.4Ghz) CPU Cooler NZXT Kraken x41 Motherboard MSI Z97 Gaming 5 Memory G.Skillz Ripjaws X 16gb 2133 Video Card MSI GTX 1080 Gaming X           Case NZXT H440 Power Supply XFX XTR 750W Modular Storage Samsung 840 EVO 250gb/Seagate Barracuda 2TB Monitor Acer XB270HU G-Sync http://pcpartpicker.com/b/3CkTwP
https://linustechtips.com/topic/303873-quiet-case-fans/#findComment-4138112
