Extra power supply cables help?
Solved by MourningSouls,
Contact Be Quiet! first, they can send new cables. Whether or not you'll have to pay is unknown to me. But it's 18 euros shipped for a full set if I recall correctly, so it shouldn't be too bad if you just want the cables you're missing.
Additionally there are companies that make custom cables you could look at. ModDIY made mine, but there is also Mainframe Customs (Formerly Lutro0 Customs) and a few others that should be easy enough to find.
