i recently brought a power color radeon hd6950 graphic card. when i installed it to my pc, my pc cannot boots. All the fans was spinning but very slow. Then i use another power supply just power up the gpu. Before power up the gpu my pc can operate normally, but when i turn it on, all the fans become slower and my pc was turn off. Why? still not enought power? gpu problem?
my psus are corsair vs550 and avf 650w,
https://linustechtips.com/topic/303545-help-graphic-card-wont-work/
the HD6950 draws a lot of power
both PSU you have used are not made to support the GPU power
what happens if you dont use the GPU?
will your PC boot up?
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
Probably low voltage output from the wall socket. It's just a hunch tho. Are you sure you connected the pins properly?
My Current PC Codename: Scrapper
Intel i5-3570 | Some LGA 1155 MOBO Some Generic DDR3 8GB 1600Mhz | PowerColor RX 560 2GB | Recycled HP Case Crucial MX100 128GB 1TB WD Blue 7200RPM | Some Generic 500w PSU | Intel Stock Cooler
Yes my PC is able to boot up.
then i think i found your problem\
you either dont use your PC with the GPU
or get a better PSU
go for at least Bronze rating PSU like Corsair CX500 or CX600 as the minimum
or EVGA 500B or 600B
