Advice on Prodigy Build
Go to solution Solved by jaypro,
There is a gap for air to flow in on the sides.
The white one comes with soft touch too, which is the one I have.  Only black comes with the mesh.
Just use pressure optimized fans and it'll be all good.
Hey Everyone, I'm planning on building a m-itx build with a Bitfenix Prodigy and the new Asus rog impact board. It's going to be a water cooled system and I'm thinking I'm going to put a  240mm radiator on the front. I was also going to get the matching front panel in black and red. I would like to get the "soft touch" one but im concerned about the airflow to the radiator. Is this going to be a problem?
https://linustechtips.com/topic/30342-advice-on-prodigy-build/
