Yeah i have heard that they are good, but they are kinda expensive also. Worth?
In my opinion, yes. The battery life was way longer than I expected it to be and they sounded better than I thought they would. I was fully prepared to send them back to Amazon for a refund but I kept them, haha.
https://linustechtips.com/topic/303367-wireless-in-ears-tips/#findComment-4122859
Expensive because they have the best battery life - go for plantronics if you wont be using them for more than a couple hours.
https://linustechtips.com/topic/303367-wireless-in-ears-tips/#findComment-4123263
Which one do you think i should buy the Jaybirds Bluebuds X or http://smsaudio.com/products/sync-by-50-in-ear-wireless-sport? I'm going to order them today so i need help here!!
I would say jay birds over those
CPU i5-4690k Motherboard asrock h97-ac RAM 2x4 Crucial Sport GPU Msi 4g gtx 970 Case Silverstone sg13b-q Storage western digital scorpio black 500gb PSU csm 450w Display(s) acerh27hl bmid Cooling intel stock cooler Yeah I know right Keyboard I'd rather not say Mouse logitech g602 Sound beyerdynamic dt990pro Operating System windows 8.1
https://linustechtips.com/topic/303367-wireless-in-ears-tips/#findComment-4131570
Can you explain why you would choose the Jaybirds over the one from SMS Audio?
Because when I took a look at it there were no reviews on it and I couldn't really find info on it so I would stick with the jaybirds until some information comes out with it. I do own the jaybirds and I like them very much although a couple things still need tweaking like the buttons and the software.
https://linustechtips.com/topic/303367-wireless-in-ears-tips/#findComment-4131820
Ok. It's a hard choice for me cus it's like this: Jaybirds got much more reviews and recommendations but the SMS Audio ones has newer technologi but no reviews yet :/
https://linustechtips.com/topic/303367-wireless-in-ears-tips/#findComment-4131903
try checking their other products and see what those are like.
https://linustechtips.com/topic/303367-wireless-in-ears-tips/#findComment-4131919
