I'll leave my PC specs down bellow but when im gaming (which is pretty much all I do on my PC, my temps are around 50-60 degrees.
Today I was rendering a 35min video and These where my temps, Is this too high? should I be worried?
Thanks
PC Specs:
Case: Corsair 600T White
Processor: i7 4770K @3.9GHz w/Corsair H60
GFX Card: GTX 970 4GB
RAM: 8GB Kingston HyperX 2400MHz
MotherBoard: ASUS z97-AR
Storage: 256GB Sandisk SSD, 128GB Sandisk SSD, 1TB Seagate Barracuda HDD
CPU:i7 4770k, Motherboard:ASUS Z79-AR, RAM:8GB HyperX Beast, GPU:EVGA GTX 970 4GB, Case:Corsair 600T, Storage:1TB Seagate Barracuda, 120GB Sandisk SSD, 256GB Sandisk SSD, PSU:Corsair TX650M, Display(s):Asus VE247H, Asus VE247N, Cooling:Corsair H60 with NF-F12, Keyboard:Razer BlackWidow, Mouse:Razer DeathAdder, Sound:Astro A40
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/
The temps are definitely a little hot. I like to keep my CPU around 70-75C at the max, but it's safe up to about 85C.
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120811
I hardly ever render videos so my CPU being at these temps for about 30 mins a week isnt a problem?
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120825
In short, yes, that's too hot. 80 and below is comfortably fine, but you're just a tad over that.
Will it cause any problems though? because its only at these temps for around 30 mins per week.
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120831
http://www.xbitlabs.com/articles/cpu/display/core-i7-4770k_12.html
"Haswell turned out to be much hotter in real life than its predecessor. The maximum permissible temperature of its CPU cores is 100°C but even in nominal operational modes Core i7-4770K would get as hot as 75-80°C even with a high-performance air-cooler."
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120836
Thanks
PC Specs:
at stock clocks with a h60 cooler that is pretty terrible tbh. you might wan to go into the bios and manually set the voltage so that its a bit lower.
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120841
so its nothing to be worried about then?
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120849
I have an adapter for the NF-F12 on my Radiator which limits it to 50% speed (I hate the sound of fans)
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120865
I wouldn't say it would be a problem, no.
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120877
its still terrible in theory you should get those kind of temps on the stock cooler, not a h60. at 3.9ghz its barely faster than a fast i5 as well.
Rig Specs:
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120878
You should be aiming for lower temps for sure and so put the work in to get it done.  Still what I presented you was a guideline and based on what they say about Haswell much hotter temps are expected compared to its predecessor.
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120884
That's fine. Hotter than most PC users like, but fine.
It's fine up till about 100 degrees C.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120916
Thanks!
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4120945
they're fine, everyone on here saying its too hot is freaking out over nothing.  rendering will typically load your cpu 100%, so letting it run for a while will get toasty, especially with a low fluid capacity AIO.
and to those saying you get those kinda temps on the stock cooler, thats BS.  I've encoded vids on my 4770k at stock clocks on the stock cooler, its got over a 100 pretty quick.  I ended up disabling multi-threading to keep temps in the double digits.
so short answer is, while its toasty, its within the design spec of intel, and is completely fine.  if you really want lower temps you need to get a better cooler, and there is certainly nothing wrong with your cpu or cooler.
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
https://linustechtips.com/topic/303237-is-my-cpu-too-hot/#findComment-4121021
