CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($316.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($87.98 @ OutletPC)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($120.98 @ Newegg)
Storage: Crucial MX100 256GB 2.5" Solid State Drive  ($104.99 @ Adorama)
Video Card: MSI Radeon R9 290X 4GB LIGHTNING Video Card  ($299.99 @ Newegg)
Case: NZXT H440 (White/Black) ATX Mid Tower Case  ($99.99 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($89.75 @ OutletPC)
Monitor: BenQ GW2765HT 60Hz 27.0" Monitor  ($388.99 @ Amazon)
Total: $1871.52
Generated by PCPartPicker 2015-02-02 13:15 EST-0500
I would be better going for this setup
https://linustechtips.com/topic/303091-noob-needs-help/#findComment-4118959
  • You could save some money on the RAM and mobo. 20$ max, but still, it's already something...
  • As pointed by SimpleG, a 1440p monitor is much better for a workstation, as it's bigger and has higher resolution, when gaming.
  • Don't buy that mouse+keyboard combo. It's not that it is bad, but the peripherals HAVE to be tested out in real life. A cheaper option might just feel a lot better to you, as well a more expensive one might seem justifiable, once you actually use it. Go to a local store, and test everything that they have. Even if they are more expensive than buying online, go, and try it anyway. It'll be worth it.
Other than that... I suppose you could switch to AMD side, if you are not video rendering. Also, at the time of this post, the Asus Strix is going for 329,99$, making it a better deal over the MSI (349,99), so get that instead.
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/303091-noob-needs-help/#findComment-4119233
