I am starting a new project build and I am doing some custom sleeving. (I will be sure to post a thread in build logs, it's my first custom designed computer)
Anyways, I removed all the pins from the 24-pin connector and I wanted to make sure that isn't an issue. As long as I get the color/voltages right on the wires, it doesn't matter which one goes where in the 24-pin correct? I no longer remember which wires were where but I assumed the voltages were the only things that mattered.
https://linustechtips.com/topic/30272-cable-sleeving-help/
Anyways, I removed all the pins from the 24-pin connector and  I no longer remember which wires were where
i loled at this
Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-387432
Huston, you have a big f'ing problem! Search the webz for the diagram.
Codename: HighFlyer, specs:  CPU: i5 2500k cooled by a H70ish(2 rad)   Mobo: MSI MPower Z77   GPUs: Gigabyte GTX 660 OC 1150 MHZ core, 3150 memory both   RAM: Corsair Vengeance 16G @1600mhz   SSD: ADATA Premier Pro sx900 / HDD Seagate Barracuda 1TB/Samsung 1TB   Power supply: Corsair RM650 80+ Gold   Case Corsair Carbide 500R   5.4 ghz achieved on the good old 2500k, may it rest in peace. Current daily OC is 4.8 @1.41 v
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-387447
Depends on the PSU, one cable wrong and you have a dead CPU/mobo/RAM/all of the mentioned.
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-387677
Unless you got a super fancy high end PSU, its all color coded.
Black is ground
Orange is 3.3V
Red is 5V
Yellow is 12V
Green is for PS#
Gray is for power on
Purple is 5VSB
http://pcsupport.about.com/gi/o.htm?zi=1/XJ&zTi=1&sdn=pcsupport&cdn=compute&tm=75&f=00&su=p284.13.342.ip_p504.6.342.ip_&tt=2&bt=4&bts=50&zu=http%3A//www.formfactors.org/developer%255Cspecs%255Catx2_2.pdf
Its all in there.
Also: Don't just say Black goes to wherever a black is.  You will want to try to make it as untangled as you possibly can, to look nicer.
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-388415
Black is ground
Orange is 3.3V
Red is 5V
Yellow is 12V
Green is for PS#
Purple is 5VSB
Its all in there.
Actually I have the same question. The 24 pin cable for my PSU has all of the cables going to different slots. Like the orange goes to where orange should be and black etc, but they arnt exactly the same positions as the other end of the cable (modular)
So it shouldnt matter which cable goes where, as long as the colours are correct?
Intel i7 3770k @ 4.5GHz, Gigabyte GA-Z77X-UD5H, Gigabyte GTX 770 4GB Windforce, 16GB G.Skill - NT 1600MHz, 250GB Samsung Evo SSD, 2x 1TB Seagate HDD, Corsair H100i CPU cooler w/Noctua Fans, 4x SP120, Fractal Design Define R4, LG W224T, Func MS-3, Apple Numeric Keyboard
-   BBR4 Hackintosh   - Server Rig
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-389928
find a diagram and label all of the connectors with a number then make yourself a little drawing of a connector and put the number of the wires where they should go.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-396166
I think a lot of you misunderstood me. I am very aware that I can look up a pin-out diagram for the 24-pin (which I did) I was simply wondering if it mattered which wire of that color went to a given slot.
I already contacted OCZ and they said it is fine as long as the colors are right.
https://linustechtips.com/topic/30272-cable-sleeving-help/#findComment-398424
